Transmission & Drivetrain Gearboxes, Differentials, Clutches
Differential or Axles (Video inside!)
Old Dec 10, 2015 | 10:50 AM
billabongrob's Avatar
Icon5 Differential or Axles (Video inside!)
I was wondering what you guys think this is. I had the transmission rebuilt with carbon synchros and a mugen plate type differential. Is this the differential or axles or what are your thoughts? Its seems like it may have unseated the axle when it's doing the popping noises. If the axle was unseated, (c-clip) would the diff try to spit it out consistently?
Any help would be greatly appreciated!
Old Dec 10, 2015 | 11:35 PM
slowcivic2k's Avatar
Default Re: Differential or Axles (Video inside!)
Provide more information. Axles, transmission, engine type. If you suspect an axle problem, why? Do you think they are too short? When did the problem start?
Since the problem appears to make the most noise while turning, a differential problem is the first place I'd start. If your differential "kicked" out an axle, the splines would show damage, and leak oil everywhere since the seals would no longer work. The knocking sound is reminiscent of a broken side gear in the differential. Since you have modified it, I would start with removing and inspecting the differential for damage. Eventually whatever may be hitting it will break, which may break the case halves as well. Google busted differentials for pics.
blake22
Suspension & Brakes
14
Sep 24, 2010 08:35 PM
dadrought6
Oct 18, 2008 11:19 AM
Rhymenoceros
Nov 19, 2007 07:22 PM
b18cEF9
Apr 21, 2004 01:22 PM
