D16z6 engine swap in a crx si
Old Dec 9, 2015 | 08:00 AM
BubbaW's Avatar
Default D16z6 engine swap in a crx si
I'm going to do a d16z6 engine swap in my 1990 crx si but I need to know in detail the stuff I need to make it compatible for my car like what Ecu to use and wiring harness do I have to use you know where I'm getting at with this I really need to be informed please help or give me information on a cheaper or easier swap
Old Dec 9, 2015 | 11:35 AM
jlicrx's Avatar
Default Re: D16z6 engine swap in a crx si
this swap has been done numerous times - check the FAQ's and do a search for "D16Z6 swap into CRX Si"
by far, the easiest swap in the CRX Si is the OBD0 JDM DOHC ZC - bolts right in with only a minor wiring change to the Si engine harness at the distributor - the ZC has more HP than any SOHC D-series engine
ryanmh22
26
Feb 26, 2013 11:33 AM
JDM RHD eg6
Dec 11, 2004 12:34 AM
dud1y3d
11
Oct 31, 2004 04:36 PM
