hello..I bought these coilovers and the seller said they were for a da/ef so I assumed they'd fit on my 91 ef hb..but they're too big for the front forks and they aren't the u mount for the rear.
They're apex'i WS coilovers that are set way too low. They look like they're meant to work with 88 CRX HF and DC2 Type R/EG6 rear control arms.
Since you're saying they're too wide for your front forks, they're probably a DC2 Type R or EG6 application.
I believe you can buy DC/EG front forks to fix the issue up front.
If you have a 88-91 civic, you can swap on 1988 CRX HF rear lower control arms to resolve the rear fitment issue. Not sure if you can do the same with DA's.
