Help!!! gsr motor with skunk2 manifold
Sup guys,, new member here!! My name manny from hawaii,, anyway im having troble with my civic swap with a 95 gsr motor and installed a new skunk2 mani,, so here it goes,, long/short story!! Aftr install i start engine and with a high rev up to 3k,, then engine dies?? Any advise what should i do .. Thankx
Sounds like a vacuum leak somewhere. Did you verify that all your vacuum lines are attached in the proper spots and aren't cracked? You might also check around all your gaskets and make sure they aren't leaking
Thankx bro for the reply,
Well i see a costume fitment on a hose with 3 way nipple,, 3/8 hose that connects to the TB and mani and also a canister below the gas filter
Post a picture of how that hose is routed. the line from the charcoal canister under the fuel filter should go to the tb by itself, and you should have one larger line from the brake booster to the manifold
Having a hard time posting a picture,, but unpluging the iacv rpm drop to normal but when pluging in it goes back to 3k rpm on idle
This should help... FFS Tech | Skunk2 Manifold for GSR Intake Manifold for GSR/P72 Head
Not quite yet bro,, got everything good with the vaccum but now its my rev, pressing gas bogs out like no rev and repeat bogs out, no power
Brand new iacv but high rev when put on plug after it warms up back to normal,, and still when gas is press it bogs out, i want it to rev up to 5rpm
Gsr Ecu is set up to run with butterfly's if you took these out to put your skunk2 manifold you now have to tune it. Otherwise, you will get bogs where the butterfly's have to engage
SuicideSlide
20
Oct 3, 2004 10:22 AM
