98 accord popping out 5th gear
Old Dec 6, 2015 | 01:50 AM
victor_509's Avatar
Default 98 accord popping out 5th gear
Title says it all my people. I hope its not the syncros. Has anyone had this issue and what they did to solve it?? Thanx
Old Dec 6, 2015 | 01:54 AM
slowcivic2k's Avatar
Default Re: 98 accord popping out 5th gear
Loss of gear position is rooted in shaft movements, meaning the bearings that support the shaft are loose, and the shift change piece is potentially worn out/bent. This allows the shafts to thrust past the shift detents during acceleration/deceleration, pushing the unit out of gear. Usually occurs in 2nd gear.
You'd wish it was the blocking rings once you see how much work and cost is required to re-bearing a transmission properly.
Old Dec 6, 2015 | 01:56 AM
victor_509's Avatar
Thanks slowcivic2k. Im really hoping its something in the gear box not in the transmission.
092eg6
Transmission & Drivetrain
Dec 2, 2009 01:33 PM
Aquafina
Sep 6, 2008 11:14 PM
Evil_Ek
Feb 9, 2006 08:33 AM
b20civic
Dec 2, 2002 05:28 PM
