Honda CR-V & Element 2WD & 4WD Element & CR-V
I need the name/part number for a replacement
Old Dec 5, 2015 | 04:33 PM
18anolan's Avatar
Default I need the name/part number for a replacement
So, the speedometer on my 2005 CRV stopped working, everything else was fine. Im virtually clueless when it comes to car repair but I checked online troubleshooting, found the issue, and found a used gauge cluster, replaced it and it worked. But during my excitement of actually fixing something I hurridly attempted putting the removable panel underneath the steering column back on so I could go brag about my newfound repairing manliness and it wasn't placed properly when I in true caveman fashion tried bashing it back into place. 2 of the plastic "securing clips?" busted off. Its secured with the screws and isnt visually broken, just loose if you grab the bottom of the panel. Im trying to find out if 1) judging by this description the specific part is clear and 2) is it a part that can be ordered. I'd like to avoid going to a junkyard and trying to explain why i need that specific panel.
actv8
May 24, 2010 12:33 PM
cb7tougeracer
May 11, 2007 03:10 AM
Pooby88
Jul 2, 2006 12:47 PM
aws140
Oct 30, 2005 09:44 AM
lephem
Mar 22, 2004 07:27 AM
