mpfi
Old Dec 5, 2015 | 04:33 PM
Joe Yaerrd's Avatar
Default mpfi
I did or attempted to do this swap..I put the battery in and nothing when I turn the key only thing is a clicking under the glove box when I connect the battery. .
Old Dec 5, 2015 | 04:42 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: mpfi
You're missing car info as well as what specific hardware you used.
Old Dec 5, 2015 | 06:31 PM
Joe Yaerrd's Avatar
Default Re: mpfi
91 sedan pm6 crx pm6 intake manifold 0db1 eg injectors
Old Dec 6, 2015 | 03:32 AM
Joe Yaerrd's Avatar
Default Re: mpfi
Anyone
Old Dec 6, 2015 | 04:41 AM
Joe Yaerrd's Avatar
Default Re: mpfi
The clicking is my seat belt power seat belts ..but I did the mini swap put everything back together .. When I turn the key nothing happens in any position blow fuse? Only thing that seems to get power is the seat belts
Old Dec 6, 2015 | 05:54 AM
Joe Yaerrd's Avatar
Default Re: mpfi
So I checked the fuse box under the hood and the 60a fuse was popped I have a hatch just to what happens I took it to that once I touched the Neg terminal and it instantly popped
Old Dec 6, 2015 | 07:16 AM
Joe Yaerrd's Avatar
Default Re: mpfi
I've read it could be the alternator it's a newer alternator wire don't seem to have any tears like I said I just did a mpfi swap everything is shrink or taped I figure there can only be a few things that will make that certain fuse go.....anything helps...and yes I've searched
hondaEg_808
26
Jan 19, 2015 03:27 PM
monster d
14
Feb 4, 2013 07:47 AM
switters959
Nov 27, 2011 12:17 PM
illnino
Dec 17, 2002 07:25 PM
