H2b not putting out
Hi everyone I had my car dynoed twice and I wasn't really impressed with how much I spent I did quite some research on the h2b all motor builds and I thought I could have made a conservative 250 on race gase. Anyhow it dynoed at 225whp and 168tq I believe on vp 116 I'll have the chart up later of exact numbers. heres a quick rundown on my setup. Some advice would be appreciated
Jdm h22 euro r motor
Jdm itr 98 spec Trans
Competition twin disc
Skunk2 pro 2 cams
Cam gears
Aries 12-5-1
Supertech valvetrain
Arp headstuds
KS tuned balance shafts eliminator installed in oil pump
KStuned Manual timing tensioner
Ported stock intake and plenum with the butterflies cut and used as a spacer no iacv due to cutting in the holes to portmatch 70mm skunk2 tb
PLM header 4-1
Rosko fuel rail
RC 550
APR fuel pressure regulator
Msd digital 6 with hvc super coil
Tuned with s300 v3
Skunk2 pro 2 cams
Cam gears
Aries 12-5-1
Arp headstuds
PLM header 4-1
Rosko fuel rail
RC 550
Tuned with s300 v3
I made that with a stock h22 with pro 1s and a skunk2 manifold. I'd get the tune checked out at another shop, also where are your cam gears at?
Only unknown would be your cam gear settings and see how far off they are from what is recommended per skunk2... Skunk2 cam gears as well?
Your not too far off on power with the stock 90.7mm stroke. Your torque seems right. 95mm will net you atleast 10 more ft lbs of torque and 10-20 more whp... I would suspect theres a few more hp in there... 10 maybe or so
I'd let the engine break in, do some runs with it and go back. Try advancing the exhaust and see what happens, my pro1s ended up with +4 on the exhaust if I remember right. Intake was at 0.
I am also concerned with how fast it does but they do go hand in hand...my stock engine did 200whp with 150ft lb of tq on same dyno so thats 20+ whp and 15 lb ft of tq net gain over my previous setup that's why I posted this I figure with this setup it's more capable
Every dyno reads different. Mustang dyno reads low. Dyno is just a tuning tool. Make sure those cams were degree in properly with clearances checked p2v & v2v.
What's your afr at wot?
Alcohol always get them to put out
thirdrail-211
Apr 9, 2005 05:03 PM
