wtf donut gasket
i have a 99 honda civic ex with a b18c itr swap in it it has a tri y apexi header trash yeah i know it has like a 2 to 2.5 in outlet and my exhaust is 60mm im having a hard time finding out what donut gasket to use to connect from the header to the exhaust someone please help me out
Specifically, what junction/flange are you mating? The bottom of the header to the catalytic converter/test pipe? (This is a flex gasket)
Or are you trying to find the gasket between the tri y's of the two piece header? (This is typically a 2 hole flat gasket)
Or the gasket on the back side of the catalytic converter/test pipe to your long pipe? (This is typically one large hole triangular shaped flat gasket)
Flex gasket is a doughnut gasket that the catalytic converter can "flex" on with the spring bolts and still seal.
It's also called a flex gasket by many sources, Honda included.
But I also explained why the terminology is used.
27
18229-SR0-003
Gasket, EX. Flexible
1 $15.75 $10.87 Submit
28
18229-SH3-X30
Gasket, EX. Flexible (50mm-64mm)
1 $25.00 $17.25 Submit
Pulled for my car but the same location just different sized gasket.
Honda Part No.: 18229-PCX-003
Fast Delivery
Dedicated Service
Guaranteed Genuine
Your Price: $23.63
Retail Price:$34.25
You Save:$10.62
Qty:
Add OEM Honda Gasket to Cart
27
18229-SR0-003
28
18229-SH3-X30
Fast Delivery
Dedicated Service
Guaranteed Genuine
Your Price: $23.63
Retail Price:$34.25
You Save:$10.62
Qty:
I think the S2000 flex gasket might be a bit big.
Did you say your outside diameter of the header was 2.0"?
If so the flex gasket on the S2000 is for 2.5" and doesn't fit.
I am thinking your header output size is the same as my two piece one and the S2000 flex gasket was much too large.
What I found fit the 2" pipe was the Walker 31357 flex gasket.
crazyboy
Oct 17, 2011 09:17 AM
