Integra body specs for strightness
Old Dec 3, 2015 | 07:33 AM
bigislandc2's Avatar
Default Integra body specs for strightness
Hi all wanted to know if anyone on here have the measuring specs for a integra dc2 for body/frame strightness. Wrecked my integra so before I proceed to replace any bulkhead parts I want to check if the rest is straight.
Is there any tolerance in being off maybe in the 32nds? The door did sag alittle but after I striped the whole car I didn't see and floor,roof,or apillars bent in any way. But first things first measure and go from there.
Old Dec 20, 2015 | 03:20 PM
Hidenplanvew's Avatar
Default Re: Integra body specs for strightness
just use a measuring tape on the other side and measure in a big X to points that match. You are better off using MM to measure over SAE. Uni body cars need to be within 3mm to be correct. Frame vehicals can be upto 5mm.
hotwh1pz
Jun 4, 2007 07:33 AM
jfteg
Oct 20, 2004 06:34 AM
