PA FS/WTT Escalade ESV
Open to Trades...
Texting is faster, pm me your number and questions
2003 Cadillac Escalade ESV Gold Package
AWD, Sable Black
80,XXX (mileage will increase, it's my daily)
Clean Title, Second Owner
Asking price: $18,000
Possible trades: NSX, ITR, S2K, JDM CRX and K swaps...
Upgrades and MODS:
24x10 Offset 31 Platinum Edition Chrome Wheels
305/35/ZR24 Nexen Roadian HP Tires
2007 Brake Upgrade: Power Stop Powder Coated Calipers, Zinc Coated Slotted Rotors and Ceramic Pads
Goodridge Stainless Steel Brake Lines and DOT 4 Motul RBF660 brake fluid
Magnecor Wires and ACDelco Iridium plugs # 41-110
Weather Tech DigitalFit FloorLiners, Cargo Liner, Side Window Deflectors and Stone & Bug Deflector
Kensun HID Xenon Fog Lights 6000K and 8000K bulbs
OEM Platinum Edition Grille
All fluids and filters changed regularly.
Oil every 5k, Chevron Fuel Sys. Cleaner x3/yr.
Mobil 1 5w30 Full Synthetic Oil, Amsoil ATF, ACDelco Auto Trak II, Amsoil 75w90 Gear Oil
Sunoco Premium 93 Octane Fuel Only
https://en.wikipedia.org/wiki/Cadillac_Escalade
MSRP: $56,380
- Features & Specs:
Engine Type: AWD - High output 6.0L V8
Fuel Delivery: Sequential fuel injection
Displacement: AWD - 364 / 6.0L (cm3)
Compression Ratio: 10:1
Horsepower/Torque (ft-lbs): 345 @ 5,200 rpm / 380 @ 4,000 rpm
Transmission: 4L60-E HD, 4-speed automatic, heavy-duty, electronically controlled
full-time four-wheel drive, single-speed transfer case w/overdrive & tow/haul mode
Towing Capacity*: 7,800 lbs.
Final Drive Ratio: 3.73
* Maximum trailer-weight ratings are calculated assuming a standard-equipped base
vehicle plus driver. The weight of optional equipment, passengers, and cargo will
reduce the maximum trailer weight your vehicle can tow. Maximum payload capacity
includes weight of driver, passengers, optional equipment, and cargo. See your
Cadillac dealer for additional details.
Fuel Economy, EPA Estimated MPG: 12 city/16 highway
Interior Dimensions:
Head room (f/m/r) 40.7/ 39.4/ 37.4 in.
Hip room (f/m/r) 61.4/ 61.3/ 49.0 in.
Leg room (f/m/r) 41.3/ 38.6/ 27.3 in.
Shoulder room (f/m/r) 65.2/ 65.1/ 64.8 in.
Passenger capacity: Eight (8)
Cargo capacity:
Behind front seats: 104.6 cu. ft.*
Behind 2nd seat 63.6 cu. ft.**
Behind 3rd row seats 10.1"
* 2nd row seats stowed and 3rd row seats removed.
** 3rd row seats removed.
Exterior Dimensions:
GVWR: 7,200 lbs.
Overall length: 221.4 in.
Curb weight: 5,869 lbs.
Width: 78.9 in.
Ground clearance: 10.7 in.
Height: 74.2 in.
Height with Luggage Rack: 75.7 in.
Chassis Dimensions:
Wheelbase 130.0 in.
Tread (f/r) 65 in. /66 in.
Turning Diameter 43.3 ft.
Fuel Tank 31.0 gal.
Features
Interior Features:
Front Seats
Multi-level heating passenger seat
10 -way power passenger seat
10 -way power driver seat
Passenger seat with power adjustable lumbar support
Multi-level heating driver seat
Driver seat with power adjustable lumbar support
Height adjustable driver seat
Height adjustable passenger seat
Leather
Bucket front seats
Rear Seats
Split-folding rear seatback
Reclining rear seats
Folding center armrest
Manual folding bench third row seats
Rear heater unit
Power Features:
Remote keyless power door locks
Reverse tilt passenger mirror provides curb view when vehicle in reverse
Power mirrors
Heated mirrors
1 one-touch power windows
Instrumentation
Clock
Tachometer
Trip computer
External temperature display
Low fuel level warning
Compass
Convenience
Adjustable pedals
Cruise control
Front, rear and 3rd row cupholders
Front door pockets
Overhead console with storage
Retained accessory power
Front seatback storage
Power steering
Universal remote transmitter (for garage door, security system, etc.)
12V rear power outlet(s)
Rear parking sensors
Tilt-adjustable steering wheel
Audio controls on steering wheel
Comfort
Three zone climate control
Cargo area light
Front and rear reading lights
Leather trim on shift ****
Leather and wood steering wheel
Rear floor mats
Turn signal in mirrors
Electrochromatic inside rearview mirror
Dual illuminating vanity mirrors
Memorized settings
Memorized settings for 2 drivers
In Car Entertainment
Diversity antenna
Bose premium brand speakers
Separate rear audio
9 total speakers
250 watts stereo output
AM/FM stereo
Speed sensitive volume control
1 subwoofer(s)
Radio data system
Telematics
OnStar telecommunications service
Safety equipment: Dual-level front airbags, side impact airbags, front passenger sensing system, ultrasonic rear parking assist, four-channel StabiliTrak stability enhancement system with ABS-based all-speed traction control, high-intensity headlamps
Major standard equipment: 12-volt auxiliary power outlet, variable intermittent speed windshield wipers, leather seating with first- and second-row heating controls, flip-and-fold third-row seat, Bulgari analog clock, Bose premium audio system with six-CD changer, tri-zone climate control, steering-wheel radio controls, power adjustable pedals, rear-seat audio, OnStar communications system, heated power folding mirrors, automatic level control
In terms of luxury, power and ride, the ESV is a Cadillac through and through. This would be a fine executive limo; the Road Sensing Suspension provides a quiet, floating ride yet with amazing roll control, and the ride height is so tall you can gaze onto the roofs of minivans as you motor along. The front independent suspension uses torsion bars and a 32-mm stabilizer bar, in back is a five-link, coil-spring design with a 30-mm stabilizer bar.
This is an amazingly maneuverable truck for its bulk. StabiliTrak and full-time 4WD keep the ESV pointed straight no matter what you throw at it. Our only anxious moment came when a wet left bend was taken too quickly, but when we lost lateral grip the slide was completely uniform and easily corrected. The Vortec is torque personified and the heavy-duty Hydra-Matic four-speed always picked the correct gear, effortlessly maintaining momentum on any road you care to drive.
The single trim level available for the ESV covers all the creature comforts. Climate controls cover three zones, there’s the aforementioned driver information center and second-row captain’s chairs, OnStar, power-adjustable pedals, a premium Bose stereo and GM’s StabiliTrak electronic stability and traction control system. Our tester’s options included a rear-seat entertainment system with a pair of infrared headphones, a remote and a Panasonic DVD player mounted from the roof (watch your head!), 17-inch chrome wheels, XM satellite radio and a tow package. You can swap out the second-row captain’s chairs for a bench seat for no charge. If you forego the DVD player, you can order a sunroof. Leather and wood trim are everywhere, although the dash template is all-too recognizable as a generic GM truck piece, and the quality of interior plastics still lags behind the competition.
The adjustable pedals and multi-adjustable electronic front seats make finding a comfortable driving posture a breeze. With its fine stereo and ride isolation, the ESV is less a conveyance and more a luxurious listening room.
AWD, Sable Black
Upgrades and MODS:
MSRP: $56,380
- Features & Specs:
Cargo capacity:
GVWR: 7,200 lbs.
Width: 78.9 in.
Height: 74.2 in.
Chassis Dimensions:
Wheelbase 130.0 in.
Fuel Tank 31.0 gal.
Features
Interior Features:
Front Seats
Leather
Bucket front seats
Rear Seats
Rear heater unit
Power Features:
Power mirrors
Heated mirrors
Instrumentation
Clock
Tachometer
Trip computer
Compass
Convenience
Adjustable pedals
Cruise control
Front door pockets
Power steering
Comfort
Cargo area light
Rear floor mats
Memorized settings
Diversity antenna
Separate rear audio
9 total speakers
AM/FM stereo
1 subwoofer(s)
Radio data system
Telematics
Tow your track monster, haul your friends and family, or take the lady out on the town in style. This beast does it all!
Please see here: Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
Cosworth
Sep 5, 2003 03:14 PM
BUMP
