needs advice please! possible swaps for 88 civic wagon
Old Nov 30, 2015 | 07:53 PM
ahhzel's Avatar
Icon4 needs advice please! possible swaps for 88 civic wagon
Hello everyone,
Could anyone tell me what kind of engines I can use for a 88 civic wagon? My friend has a B18B1 engine from an acura, not sure if it is possible. Thanks guys.
Anyways my current situation is that my honda engine needs a rebuild from the bottom up unless I swap it, I got a quote from someone way saying they can do the rebuild for 800 labor and 400-450 for the parts. Could I have some advice please on what I should rather do?
Thanks for all the help.
Old Nov 30, 2015 | 09:13 PM
93egSLEEPER's Avatar
Default Re: needs advice please! possible swaps for 88 civic wagon
k24
Old Dec 1, 2015 | 11:18 AM
bigtimegambler's Avatar
b18a is cheaper, and you can keep obd0. That is the cheapest option for better power. Or you could swap in a d16a6 that is healthy for even cheaper and keep obd0. It seems like you are on a strict budget. Hope this helps.
Old Dec 2, 2015 | 07:17 AM
PyroProblem's Avatar
If you swap to the b18 engine, you'll need all the b series swap stuff to go with it. (trans, linkage, axles, mount kit,etc).
Staying with a D series (like the factory installed engine) would be the easiest and probably cheapest.
Any engine swap is possible depending on your budget.
Old Dec 2, 2015 | 08:06 AM
cut to fit linkage, use a combination of oem honda b and d series mounts, axles are cheap. It can be cost effective. an ls transmission and b18a would only run like 300 dollars at pick and pull. then just grab a couple other things (like axles and mounts) and you could be on your way for less than 400 dollars.
Daniel Wirfs
Jun 17, 2019 06:08 PM
ahhzel
Nov 23, 2015 06:21 PM
gagedally
Honda Civic (2001 - 2005)
Feb 3, 2013 06:01 PM
jjohn6438
Nov 13, 2006 11:51 AM
tcav52
Oct 28, 2006 09:35 AM
