What is the ideal ride height for street use and handling for a 1997 civic
Old Nov 30, 2015 | 02:19 PM
theguy22's Avatar
Default What is the ideal ride height for street use and handling for a 1997 civic
I currently have function and form type 1 suspension and the max height is still too low for the city streets in my area. currently the fender is about the same level as the top of the tire ( i have fat 5 wheels with low profile tires ). Is tokiko blue with springs a good suspension? Does anybody have the same problem with function and form suspension?
Old Nov 30, 2015 | 03:05 PM
theguy22's Avatar
Default Re: What is the ideal ride height for street use and handling for a 1997 civic
bump
Old Nov 30, 2015 | 03:09 PM
NotARaCist's Avatar
I never narc'd on nobody!
Less than 40 minutes. Relax, man, you can't always expect an instant answer.
Sounds like there's something else going on with your suspension that you aren't telling us, or aren't aware of. I also have F/F T1's (they're crap, for anyone curious) on a 6G, and at around the middle height, I still have wheel gap. Are you adjusting using the spring perch, or the base perch? Have you inspected them for blowout? Do you have some other aftermarket hardware in your suspension that you aren't mentioning?
The usual go-to is Koni Yellows with Ground Control springs. Check the marketplace - I believe there's a vendor that sells a well priced package with everything you'll need.
Old Nov 30, 2015 | 04:10 PM
turnsignalandy's Avatar
The correct ride height for a 92-00 Civic is Stock. Lowering these cars will shift your roll center farther away from the center of gravity, thus increasing your roll moment. Roll center adjusters can probably be used to correct that although im not sure how much they help. If you want the best bang for your buck get sticker tires.
Old Nov 30, 2015 | 04:23 PM
White_EG1's Avatar
Running -3.5 in the front and can say after 80 the car just sways side to side, pretty dangerous. But of course in the curves it handles good.
Just lower it 1.5 in you shouldnt have any problems.
Old Dec 1, 2015 | 10:44 AM
bigtimegambler's Avatar
Just lower it '1.5 you shouldnt have any problems.
Still shouldn't sway side to side at 80. You have other problems to worry about. I had an integra that had around the same camber, and at 100 it wouldn't even sway side to side. You have worn out bushings.
Old Dec 1, 2015 | 01:53 PM
NotARaCist's Avatar
Yeah, swaying at 80 isn't a "how low are you" issue, it's something else. Bad alignment, uneven ride height, or a bent frame.
Old Dec 1, 2015 | 02:53 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
F&F isn't exactly a reputable company. Their setups are made to go low for cheap. Which is what yours is doing.
I wouldn't buy Tokico blues and springs. Its not that great of a setup, and blues are WAY overpriced.
If you just want shocks and springs, the best way to go would be Bilstein HD/B6 and Eibach prokit springs. Thats about a 1.2 - 1.5" drop. That is the MAX drop you want from stock length shocks and soft springs.
Other very good cost effective options would be Tein Street Advance or Street Basis. About a 1.5 or 2" drop won't be an issue with these. They are height adjustable, and have all the right features for a street car.
Old Dec 1, 2015 | 02:55 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
You have caster/toe problems if you are 'swaying' like a boat.
Most likely you need an alignment.
Old Dec 1, 2015 | 09:20 PM
I thought caster is non-adjustable on hondas. So if its bad caster it would be a bent front lca, worn out bushings, bent frame, or a combination of the three?
Old Dec 1, 2015 | 09:36 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Pretty much. And alignment tech should be able to show you what is bent.
Old Dec 2, 2015 | 01:17 PM
White_EG1's Avatar
You guys are right I just looked at my alignment sheet, and forgot I have a pretty bad caster issue. I have a bent front LCA. So disregard my comment lol.
Old Dec 2, 2015 | 01:27 PM
conor97hx's Avatar
an alignment should be the first thing you get after any alterations to suspension.
Old Dec 2, 2015 | 02:56 PM
B serious's Avatar
I was assured that you should buy longass purple (or similar coloured) lug nuts as a complimentary second mod, immediately following any suspension work.
They cost the same as an alignment. So....
Old Dec 2, 2015 | 03:03 PM
Thats only step 1.
Step 2 is to buy tow hook and strap your rotas to them using takata harnesses.
Step 3 is alignment.
Old Dec 2, 2015 | 06:07 PM
White_EG1's Avatar
No, Step 3 is a neo chrome tie bar
Old Dec 2, 2015 | 08:27 PM
step 4 is go to a car meet and preach about how much a tie bar increases chassis rigidity.
Old Dec 2, 2015 | 11:11 PM
NotARaCist's Avatar
and step 5 is to get your **** stolen by some lowlife who goes to every car meet just to find **** to steal.
Old Dec 3, 2015 | 08:41 AM
B serious's Avatar
Y'all know y'all steps.
Old Dec 3, 2015 | 10:20 AM
White_EG1's Avatar
Thats deep.
Tpunep
Suspension & Brakes
16
Sep 20, 2014 12:42 PM
siqueen23
Mar 24, 2008 09:09 PM
100miles+
Honda Civic (2006 - 2015)
Mar 11, 2008 07:18 PM
wicked2night
Suspension & Brakes
Aug 2, 2006 10:46 PM
'89 hatch
15
Jun 26, 2002 05:59 AM
