Compatable transmissions for an 99 accord
A '99 Accord comes with a 2.3L 4 cylinder engine... yet you mentioned a 2.4L. Does this mean that you have or intend to swap in a K24 and need to know what transmissions will be compatible or do you need a list of compatible transmissions for the original F23 ???
Nearly any front-wheel drive F or H series (there are dozens of them) from an Accord or Prelude will bolt up fine. You may want to make yourself familiar with some of the common transmission codes if you plan on perusing a salvage yard because the gearing can be very different.
H/F Transmission Codes/Ratios - Honda Prelude Forum : Honda Prelude Forums
asbestos2001
Jan 6, 2009 01:32 PM
Havokmkr
Apr 1, 2003 12:23 PM
