Crankshaft wire harness
Old Nov 27, 2015 | 06:25 PM
Bob Nealey's Avatar
Icon5 Crankshaft wire harness
Hi .I bought a 1995 Honda Del sol without a engine and the wire harness that hooks to the engine. So my plan was to buy a engine and rebuild it and also buy a wire harness to in stall under the hood.The motor I bought was a 1999 Honda Civic 1.6 vtec. Now the problem I came in to was trying to find a wire hardness for the car .So what I did was went to the junk yard to find one lol that never happen. But the junk yard said a Honda Civic around the same year of my car would work OK did that now the problem is the wire harness does not have a plug for the Crankshaft senor to plug in lol''' So my question is how can I bypass the ECU or how to make this work? Or any Ideas will work thank you so much
Old Nov 27, 2015 | 06:37 PM
JarvisW's Avatar
Sol to Sol
Default Re: Crankshaft wire harness
you have an ODB1 car and an ODB2 engine.
You'll have to get the ODB2 harness all the way from engine to the PCM which will also have to be an ODB2.
Or, sell/trade that engine for the D16z6 engine that belongs in that car. (or the B if its a Vtec model)
Good luck!
Old Nov 27, 2015 | 07:33 PM
NotARaCist's Avatar
I never narc'd on nobody!
That's not even remotely his only option, Jarvis, nor is it his best option.
OP, you can get a harness out of any 92-95 Civic or Del Sol (same part number between the two chassis). Preferably one out of an EX or SI with a standard transmission. You'll need to use a chipped ECU, but beyond that, what you want to do isn't exactly hard.
Old Nov 27, 2015 | 10:41 PM
bigtimegambler's Avatar
a d series harness could would work with some modification. As for the ecu, as NARC stated, a chipped ecu (obd1) will allow you to run your car without the crank sensor input.
Old Nov 28, 2015 | 03:05 AM
rudebwoy's Avatar
At this point the crank sensor is not an issue at all, consider it decoration.
your options:
*Obd1 vtec harness 92-95
*distributor jumper harness from OBD1-OBD2
*P30 ECU, or a chipped p28 because the P30 will require a knock sensor input.
*you will need to hard wire your intake temperature sensor to the OBD1 harness
*your purge solenoid also has a different style connector.
*your alternator has a different connector.
*all this is easy to achieve.
Old Nov 28, 2015 | 07:52 AM
Bob Nealey's Avatar
Thanks guys the harness I got from the junk yard came from a 93 Honda civic Auto 1.6 which didn't have a crank senor so it must be in the Distributor.Could I use the same distributor? The wire harness plug into the car just fine and the other plugs fit just fine.
Old Nov 28, 2015 | 01:10 PM
HondaPartsHero's Avatar
Technical Hero
If you use the 99 you'll need an adapter harness or find a 92-95 non VTEC distributor. BTW all crank position sensors are in the distributor on 88-00 Honda Civics only the crank fluctuation sensor is at the crank on 96-00 Civics, which isn't the same as crank postion.
Old Nov 28, 2015 | 02:59 PM
Bob Nealey's Avatar
May sound dum But what is the different between a v tech and non v tech Distributor? The head is a v tech .
Old Nov 28, 2015 | 03:07 PM
rudebwoy's Avatar
A non Vtec distributor WILL NOT fit a B16 head. they have different mounting points.
As I've stated in my response up top your best bet is to get a distributor conversion harness.
I used to go as far as to transfer the internals from D series distributor into the housing of my B series Vtec distributor.
Old Nov 28, 2015 | 03:21 PM
Bob Nealey's Avatar
Where can I get a conversion harness at? How would I know if it is the right one?
Old Nov 28, 2015 | 03:28 PM
rudebwoy's Avatar
OBD1 to OBD2 Distributor Jumper Harness - WIREWORX
http://www.rywire.com/rywire-distrib...ers-s/1877.htm
Bob Nealey's Avatar
I have a v teck distributor
Old Nov 28, 2015 | 03:30 PM
Bob Nealey's Avatar
Thanks man This stuff is not my thing lol I'm more a Gm guy I'm lost on this stuff lol
Old Nov 28, 2015 | 03:41 PM
rudebwoy's Avatar
you know this is a first right? Usually we don't give all the answers because they are easily searchable.
Old Nov 29, 2015 | 07:07 AM
Technical Hero
I was assuming it was a SOHC 1.6 VTEC which he didn't specify. In which case a d series distributor will fit. OP please specify if it's a DOHC VTEC or SOHC VTEC.
Old Nov 29, 2015 | 07:30 AM
94EG8's Avatar
Seagull Management
OP, which engine do you have? The engine code is stamped into the front of the block as shown below:
Did the new engine come complete with the distributor, fuel rail, injectors, etc?
g0tgot
Jul 20, 2007 08:41 AM
Drake71400
Mar 25, 2003 04:48 AM
