Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Brake Trouble Light Stays On
Old Nov 27, 2015 | 04:30 PM
Z20rider's Avatar
Default Brake Trouble Light Stays On
Can't get the brake warning light to go out. Unplugged the e-brake switch and the brake fluid level switch and the light stays on. All 3 brake lights are working. I tested the e-brake switch by checking continuity while pressing button on switch. Continuity changes when pressing button. Checked continuity on level switch with level full (no continuity) and with no level in reservoir ( switch has continuity with reservoir empty). What is next?
Old Nov 30, 2015 | 07:21 AM
NDNV's Avatar
Default Re: Brake Trouble Light Stays On
Check the ground for the brake fluid switch and proper level of brake fluid in the master cylinder.
Not sure if a burnt filament in the brake light bulbs causes the light to come on in this vehicle or not but check that both filaments work in the brake bulbs anyway.
Hardrock1l
Apr 25, 2017 08:20 PM
backyard_tech
Jul 4, 2011 11:29 AM
riznup23
May 3, 2010 05:55 AM
jdmdc2boi12
Honda Motorcycles
Jul 18, 2009 07:37 PM
BigAnteg
19
May 21, 2009 05:44 AM
