Fuel prime problem
Old Nov 25, 2015 | 06:02 PM
808civi's Avatar
Default Fuel prime problem
What up guys
I have a 92 civic si 5 speed with the d16z6
And my fuel pump won't prime
I know it works because when I jump the relay the fuel pump primes
But the check engine light stays on and the cars just cranks but doesn't turn over I have a newly repaired ecu, main relay, sanded down ground by thermo, and I'm getting spark but still nothing
It's really starting to get frustrating
Thanks for your time
Old Nov 25, 2015 | 06:54 PM
that_boy_sammy's Avatar
Default Re: Fuel prime problem
Loosen the top bolt of the fuel filter and turn the key to the on position. See if gas sprays out. If it don't try relocating the pumps ground. Be sure the Ignition switch is good and main relay.
Old Nov 26, 2015 | 01:55 AM
delsolintegra's Avatar
Will that "newly repaired ECU" start another car?
Sometimes even replacing all the capacitors in a ECU doesn't fix the fuel pump priming circuit. Soldering skills or something else, I don't know.
Old Nov 26, 2015 | 08:43 AM
Former User's Avatar
Details? Pin 1 to 7 and pin 5 to 7?
But the check engine light stays on...and I'm getting spark
Are you sure there's spark at the plugs?
Old Nov 26, 2015 | 11:33 AM
808civi's Avatar
I jumped 1 and 7 at the relay, pump turns on
But not between 1 and 5??
I know I got spark at plugs used a screwdriver and had someone crank it
Old Nov 26, 2015 | 11:34 AM
808civi's Avatar
I don't have another vehicle to test ecu
But it was repaired by auto comp
Old Nov 26, 2015 | 11:55 AM
Do the 1-5 test with key in ON(II)?
Old Nov 26, 2015 | 12:14 PM
808civi's Avatar
Just got car to start
I had let the car sit with ignition on until engine light went away (about 10 minutes)
And it started right up
But ran weird like its out of timing or flooded or something
I just took the plugs out and there fairly black at tips
Old Nov 26, 2015 | 12:15 PM
Sounds like the ECU is bad.
Old Nov 26, 2015 | 01:15 PM
808civi's Avatar
But I just got repaired?
Old Nov 26, 2015 | 01:16 PM
808civi's Avatar
And there's nothing between 1 and 5 with key on
How much did you pay for the "repair"? Is there a warranty?
Sorry, typo. Try 5-7.
Old Nov 26, 2015 | 01:35 PM
808civi's Avatar
Yea got a 2 year warranty
Old Nov 26, 2015 | 01:36 PM
Get a refund or return for proper fix.
808civi's Avatar
And $450
This **** is aggravating
Old Nov 26, 2015 | 01:37 PM
Wow! It would have been MUCH cheaper to buy a known good used ECU.
Old Nov 26, 2015 | 01:55 PM
NotARaCist's Avatar
I never narc'd on nobody!
$450 for a repaired ECU? Holy hell. Xenocron sells stock P28's for $190. You got taken for a ride.
Old Nov 26, 2015 | 03:47 PM
808civi's Avatar
Where can I get the $190 ones ?
Old Nov 26, 2015 | 03:52 PM
808civi's Avatar
Oh sorry xenocron
Old May 29, 2016 | 05:42 PM
Alika521's Avatar
Try eBay
spens 91 Ef
Jul 3, 2013 07:16 AM
madmax94
Feb 28, 2011 02:03 AM
krysted9354
20
Apr 8, 2009 03:32 PM
PatrickFrantz
Aug 21, 2008 05:53 AM
92hatchboi
11
Apr 24, 2007 07:59 AM
