D16Y8 Oil Leak
Old Nov 25, 2015 | 12:26 AM
David Guevara's Avatar
Default D16Y8 Oil Leak
I been having this leak ever since I bought this car, so far Ive changed the distributor and Ive replace the Vtec Gaskets also the Valve Cover gasket and I still have this leak at this point I have no idea what it could be, any suggestions? Thank you in advance
Old Nov 25, 2015 | 04:41 AM
Ohmega's Avatar
Default Re: D16Y8 Oil Leak
Hard to tell from this picture, maybe cam seal?
Old Nov 25, 2015 | 09:28 AM
Heres another picture
Old Nov 25, 2015 | 01:23 PM
NotARaCist's Avatar
I never narc'd on nobody!
Clean that area with engine degreaser. Scrub it until you can eat a light meal off of it. Then let the car run to warm up and follow the leak from it's source. Simple as that.
Old Nov 25, 2015 | 10:43 PM
Jimi Hondrix's Avatar
Oil that drips to that area is usually either ditributor O-ring or cam seal.
A Vtec solenoid leak usually travels under distributor/ECU sensor and along the top of the transmission.
Did you use Hondabond or RTV sealant in corners (per FSM) during the valve cover gasket install?
Old Nov 26, 2015 | 03:09 AM
No I didnt use Rtv or honda bond, and I changed the vtec gaskets along with the distributor and nothing has helped, Only thing I havent changed was the cam seal
Old Nov 26, 2015 | 03:11 AM
The leak I have is ontop of the transmission right underneath the distributor and it drips down onto the transmisson
Old Nov 26, 2015 | 08:36 AM
Former User's Avatar
The leak is likely from the distributor and/or the VTEC solenoid. You'll make progress by determining which. The ball is in your court.
Old Nov 26, 2015 | 06:15 PM
Hondabond or Yamabond your Vtec solenoid seal. Clean both block and Vtec solenoid mating surfaces thoroughly and be careful not to get any on the screen. Also, Hondabond the valve cover gasket corners per FSM.
hondacrx2
Sep 12, 2016 12:31 PM
Vague
11
Jan 2, 2016 08:21 AM
PatrickGSR94
Dec 19, 2014 08:02 AM
danielblushtein
Mar 16, 2009 12:33 PM
type Gendy
11
Jul 12, 2003 11:26 AM
