Pressure plate bolt..size?
Old Nov 24, 2015 | 08:51 PM
TOO MUCH TORQUE's Avatar
Default Pressure plate bolt..size?
car: 2001 integra LS
Does anyone know what size the pressure plate bolts are? I was told both 10mm and 14mm 12pt. Thanks
Old Nov 24, 2015 | 09:43 PM
B_Swapped93's Avatar
Default Re: Pressure plate bolt..size?
10mm 12pt 6 of them don't go using regular bolts for that tho OEM specific/ARP ones only.
Old Nov 24, 2015 | 10:20 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yea oly use OEM or better id recomend ARP bolts for the fly wheel and preasure plate, i replaced mines with those when i upgraded my clutch.
Old Nov 25, 2015 | 08:29 AM
Thanks guys! Im sticking with oem bolts. It's going to be a stock clutch disc replacement.
Old Nov 25, 2015 | 08:32 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
ARP's I believe cost the same as the OEM bolts or are cheaper. I can't remember. I may have just ordered them from ARP because it was easier, and it's an 'upgrade'.
And you can use the extra PP bolts for your distributor=show points
Old Nov 25, 2015 | 08:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The bolt size is actually 8mm x 1.25 pitch, but the bolt head size is 10mm 12-point.
Old Nov 26, 2015 | 06:31 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
They are a M8x1.25. But have a 10mm drive with a 12 point high torque flanged head. Weird bolts for sure. Probably to force you not to use hardware store bolts, as a regular 12 or 13mm hex drive probably won't physically fit.
Buying from a dealer is a good idea.
appelsos
15
May 15, 2013 03:03 PM
DennisWaller
Dec 5, 2008 04:34 AM
Kongo69
Honda Civic (2001 - 2005)
Jul 5, 2008 02:51 PM
HondamanXxX
16
Jun 29, 2007 04:17 PM
integra3586
Feb 20, 2006 10:07 PM
