2000 civic si no start
Old Dec 19, 2014 | 12:57 AM
The Neutron's Avatar
Default 2000 honda civic cranks but wont start
Hi i have a 2000 honda civic. B16a2 motor and a 5spd transmission. The other day i was at a light and when i let the clutch out it lost power and stalled and wouldnt start. I have a code reader but it just says "connecting". It used to read the codes before. I unplugged the negative terminal on the battery and checked all the fuses. Any ideas as to what it could be?
Old Dec 19, 2014 | 05:21 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: 2000 honda civic cranks but wont start
Jump the service connector instead and jot down the codes that way.
Old Dec 19, 2014 | 06:02 AM
Former User's Avatar
For the code reader issue, voltage test 7.5A hood fuse 43. See FAQs sticky for fuse box diagrams.
For the no-start issue, do these:
1) Turn key from off to ON(II). (i) Does the CEL in the cluster turn on and stay on or turn off after 2 seconds? (ii) Does the fuel pump prime for 2 seconds?
2) Is there spark at all 4 spark plugs?
Old Dec 19, 2014 | 06:21 AM
HOMEMADEPOWER's Avatar
I had a similar problem like you and I had to change my distributor cap and rotor.
Old Dec 19, 2014 | 06:37 AM
09chaplak's Avatar
Loves Tossing Salad
OP, please don't go buy a distributor cap and rotor just yet because of this last post. Get the codes up first and then we'll go from there
Old Dec 19, 2014 | 01:12 PM
Im not getting spark so most likely distributor. But why would my computer still not read the codes?
Old Dec 19, 2014 | 01:13 PM
Does the fuel pump prime?
Check fuse 9 and whether the timing belt snapped.
As mentioned, you can skip the code reader and pull codes by jumping the service connector.
Old Dec 19, 2014 | 02:03 PM
tony_2018's Avatar
Fish Twig
What ecu?
Old Dec 19, 2014 | 03:00 PM
Well my check engine light dissappeared.. but fuse 9 is fine but i dont hear the fuel pump priming and i have the p2t ecu
Old Dec 19, 2014 | 03:06 PM
No spark, no fuel, and CEL doesn't work.
Swap the CEL bulb with a known good one in the cluster and then check whether the CEL now works.
Also check fuses 44 and 13 using a multimeter.
Old Dec 19, 2014 | 03:19 PM
Swapped the CEL bulb and still doesn't light up
Old Dec 19, 2014 | 03:20 PM
Also turn key yo ON(II) to check whether the oil pressure light turns on and stays on.
Old Dec 19, 2014 | 03:25 PM
Fuses are fine.
Old Dec 19, 2014 | 03:27 PM
Originally Posted by The Neutron
Fuses are fine.
State how you know this^ to be true or properly test them.
Old Dec 19, 2014 | 03:28 PM
Oil pressure, battery, brake and SRS lights are on.
Old Dec 19, 2014 | 03:29 PM
I pulled them all and read the ohms for each and replaced bad ones
Old Dec 19, 2014 | 03:30 PM
Unplug the main relay and test whether the main relay connector gets battery voltage from both fuse 44 and fuse 13.
Old Jan 5, 2015 | 11:24 AM
Default no power to ECU, 2000 civic
Hi i have a 2000 honda civic with a b16a2 motor swap with a 5spd. It cranks but doesnt start. No spark or fuel. No power to the ECU (p2t). Tested pins b1&2 and b9&10. Anyone have any idea where the problem would be? My fuses are all good.
Old Jan 5, 2015 | 11:25 AM
grumblemarc's Avatar
The Grumpiest
Default Re: no power to ECU, 2000 civic
Grounds.
Old Jan 5, 2015 | 11:28 AM
I cleaned up one ground. I should also mention i was driving and the car stalled and wouldnt start.
Old Jan 5, 2015 | 12:33 PM
Test whether voltage from fuses 13 and 44 reaches the main relay connector.
Old Jan 5, 2015 | 01:16 PM
Where is the main relay? Ive been looking and cant find it
Old Jan 5, 2015 | 01:17 PM
Right of glove box.
The main relay connector:
Old Jan 5, 2015 | 02:50 PM
Figured it out. Fuse 44 was blown. I had only checked the ones under the dash.
Old Jan 6, 2015 | 07:35 AM
If it blows again, there's a short in the circuit.
