Honda CR-V & Element 2WD & 4WD Element & CR-V
2002 Crv bottom dash removal
Old Nov 24, 2015 | 08:40 AM
aneelmaan's Avatar
Default 2002 Crv bottom dash removal
Hey everyone, while running my microphone cable down the a pillar and down into the dash area, it got stuck on a bar and I can't remove it. The only way for me to access it is by removing the lower dash, but I can't seem to find how to take it off. So far, I've only found the screw that's behind the coin tray. Any help would be greatly appreciated. Thanks!
Old Nov 24, 2015 | 08:58 AM
EJ8_Man's Avatar
Default Re: 2002 Crv bottom dash removal
Take off the fuse box there's one screw in there as well. To rest of the removal involves the dreaded tabs/clips. I started at the lower left corner, and even being as gentle as I could be I still busted one of them off. If I could do it again I would have hit them with some WD40 first, and let them sit for a few minutes. Feel behind the lower portion of the plastic cover and locate the tab, if you can get some WD40 on it do it. If not pull evenly, and in the direction of the tab until it pops out (or breaks off). There are plastic tabs located strategically on the lower cover. Try to use your hand underneath the dash cover as close to where the tab is located to add support to the plastic.
I assume the 2002 is the same as a 2006. I have a 2006
GSRkrod
Jun 14, 2007 09:06 PM
HybridGSR1
Jun 20, 2003 05:31 AM
WheAs MaI MojO
Nov 22, 2002 04:16 AM
99_SH
Nov 18, 2002 08:53 PM
01-1293
Mar 31, 2002 08:38 PM
