No start help
Old Nov 23, 2015 | 07:29 PM
jonyi27's Avatar
Default No start help
99 civic ex, auto, 197k miles...female friend drove the car till it over heated car shut off, she waited till it cooled, turned on drove home...I came, seen Heater hose popped...changed that... Put everything back together...first time I turned it over it turned on went to 500rpm then died, didn't want to start after that...when I kept trying it wanted to turn on but didn't, then now clicks once and pretty hard...
Checked starter they said it's fine
Put different good battery..didn't work...
Fresh oil just in case nothing
What else can it be???
Old Nov 23, 2015 | 07:42 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: No start help
can you turn the motor by hand?
Old Nov 23, 2015 | 08:17 PM
jonyi27's Avatar
Got to dark to try, in a sketchy neighborhood, gonna try tomorrow... How do you do it, try turn crankshaft pulley and see if it turns right? If it doesn't it's locked up?
Old Nov 24, 2015 | 05:49 AM
17mm crank bolt, turn with socket wrench
Old Nov 24, 2015 | 06:23 AM
Jimi Hondrix's Avatar
Just to add: remove spark plugs (optional, but easier to turn)
Turn in counter-clockwise direction (firewall towards radiator)
If you opt to remove spark plugs check them for wetness: coolant and/or oil
ef9_pr0jekt
Mar 7, 2020 07:44 AM
OldskoojdmDA9
Feb 1, 2010 04:13 PM
TurboedGSR
Sep 18, 2002 05:23 PM
