Werid Chirping noise coming from Trans
Hello, just the other day, I when to go start up my car I hear this chirping noise from the transmission.
The chirping noise only happens, when the clutch pedal is completely depressed. However, if the clutch pedal is just pressed in slightly the chirping noise goes away.
I am guess it is the throwoutbearing. If it is the throwoutbearing, will I have to replace it? What if happens if I don't replace it?
I plan on getting a gsr long block in 1-2 years. Is it worth replacing the bearing now? Or shall I fix it when I am doing the swap?
B18b1 /w gsr trans
B18b1 /w gsr trans
