Spoon N1 Install
Old Nov 6, 2002 | 01:39 AM
Jim80y's Avatar
Default Spoon N1 Install
Did a search, just need to know the tools needed and procedure for installing my Spoon N1.
Old Nov 6, 2002 | 01:56 AM
RagingAngel's Avatar
Default Re: Spoon N1 Install (Jim80y)
WD-40 for the bolts, rubber hangers...
jack.... and 3/8ths 12mm socket.
unless you have a really low car and short stroke dampers you'll need to unbolt the rear LCA to get everything done.
Old Nov 6, 2002 | 02:03 AM
B2FiNiTY's Avatar
Default Re: Spoon N1 Install (RagingAngel)
Perfect
Old Nov 6, 2002 | 10:42 AM
Unlimited's Avatar
New User
it is a bitch to get the pipe over the lca
Old Nov 6, 2002 | 11:02 AM
N1-R's Avatar
New User
Old Nov 6, 2002 | 11:03 AM
Jackson's Avatar
Default Re: Spoon N1 Install (B2FiNiTY)
Remember to loosen from the bolt side, not the tack welded nut on the b-pipe.
Old Nov 6, 2002 | 11:04 AM
IGGY's Avatar
Default Re: Spoon N1 Install (N1-R)
DO NOT USE WD40 ON RUBBER HANGERS!!!!
The oils in that stuff degrades the rubber! Use water instead.
Old Nov 6, 2002 | 11:07 AM
yellow blur's Avatar
Default Re: Spoon N1 Install (IGGY)
Really? I've used wd-40 for the past 2 years when doing my exhaust changes, hangers seem to have held up fine.
Btw, where did you get your n1 from?
Old Nov 6, 2002 | 11:17 AM
Jackson's Avatar
Default Re: Spoon N1 Install (yellow blur)
I use armor all.
Old Nov 6, 2002 | 11:44 AM
Chris's Avatar
Default Re: Spoon N1 Install (Jackson)
USE WATER on the hangers
Old Nov 6, 2002 | 11:45 AM
Dave-ROR's Avatar
Default Re: Spoon N1 Install (Chris)
pussies, the hangers aren't that hard to get off.
[Modified by Dave-ROR, 3:46 PM 11/6/2002]
Old Nov 6, 2002 | 12:16 PM
Mullet_SyTy's Avatar
Default Re: Spoon N1 Install (Dave-ROR)
Don't worry about the WD40 melting your hangers. WD40 works great for that, getting tar off of the paint and even as aftershave.
If you really buy into that crap then use silicone spray.
Petah
Jan 12, 2009 06:39 PM
gwakie
Apr 29, 2007 10:59 PM
mikkey1
Jun 9, 2006 10:46 PM
kruthles
Feb 27, 2004 04:56 PM
Edwin
Jul 29, 2002 05:35 AM
