ITR trunk wall brace.
Old Nov 21, 2015 | 09:13 PM
B_Swapped93's Avatar
Default ITR trunk wall brace.
Long story short sold it to a kid thinks his normal tegg doesn't have the holes for it can someone confirm if a normal tegg has these threaded holes.
Old Nov 21, 2015 | 09:16 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: ITR trunk wall brace.
nope! its one of the many chassis diffrences in what makes the R differ from the other tegs. Theres a write up somewhere on how to install it on a non R.
Old Nov 21, 2015 | 09:45 PM
You sure, he just told me he found them... if I still had one i'd go look but I could swear I had them
Old Nov 21, 2015 | 09:51 PM
wunfstgsr's Avatar
Loved
Community Favorite
diy Type R trunk brace Install - ClubIntegra.com - Acura Integra Forum
http://www.team-integra.net/forum/11.../182633?page=1
Old Nov 21, 2015 | 10:08 PM
Hmm ok thanks as always man, guess you need a nut on the back
Old Nov 21, 2015 | 10:17 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yea but i guess its poinless to have if you dont have a R. The bar is bolted to a brace thats welded to the frame. The other integras dont have it which makes it just for looks.
Old Dec 1, 2019 | 06:36 PM
RichD14's Avatar
You just have to remove the black plugs on the bottom, use a bolt and nut with a lock washer on the back to create something for it to thread into that will pull tight. It definitely will make a difference on a non-type r also, I installed one on my R swapped DC4. You can also drill and rivet the contact points where the bar bolts down through to the chassis and through the frame rails and make it even more rigid.
skafia
Aug 29, 2013 09:32 PM
peshte
Oct 24, 2006 01:23 AM
Baggy Spandex
Apr 3, 2006 07:06 AM
PiYoImuT
Nov 22, 2003 08:11 AM
speedymon
Dec 11, 2001 04:33 PM
