Transmission & Drivetrain Gearboxes, Differentials, Clutches
Turning a hydro trans onto cable operated?
Old Nov 18, 2015 | 03:12 PM
NicholasT's Avatar
Default Turning a hydro trans onto cable operated?
Hey guys, I got my B18a1 a few weeks back and have begun the build. It came with the original transmission (hydro) and I'm wondering if it's possible to use it with my cable set up. I found these brackets on ebay that supposidly convert the tranny over to cable. Has anyone ever heard of these? Good idea or bad? Thank you. Heres the link: http://m.ebay.com/itm/CIVIC-CRX-B-H-SERIES-CABLE-TO-HYDRAULIC-TRANSMISSION-TRANNY-MOUNT-BRACKET-PLATE-/252123934560?nav=SEARCH
Old Nov 18, 2015 | 11:20 PM
king06's Avatar
Default Re: Turning a hydro trans onto cable operated?
I don't have any experience, however that thing is going to have so much play your going to hate it and most likely it won't work properly.
Another thing you can do is convert the car to hydro or switch the case to a cable big spline.
Old Nov 19, 2015 | 09:56 PM
m4xwellmurd3r's Avatar
I havent used that one, but the hasport kit sucks. Spend the money and get the innovative kit. Friend of mine installed in on a f2b swap with a stage 4 clutch and it feels factory smooth. The hasport kit was so bad we couldnt even actuate the clutch and almost broke his pedal. The full mechanical conversion kits seem to be pretty poor at their job, but hybrid systems, while more expensive, work great
https://www.innovativemounts.com/Pro...ductCode=41001
Old Nov 20, 2015 | 09:33 AM
Hasport's Avatar
the hasport lever assembly was never meant for anything more than stock or stock style clutches. anything more and it binds up. that is why we came out with the CMA which uses a master cylinder acutated by the clutch cable
Old Nov 24, 2015 | 02:40 AM
I know, thats why i pointed out that with a stiff clutch it binds. A stock pressure plate it gets the job done though.
A lot of people dont realize that with a stiff clutch you need to either go full hydro or use a hybrid system
Old Nov 29, 2015 | 03:55 AM
94EG8's Avatar
Seagull Management
Get a transmission case from a '92 - '93 Integra and put the guts from the transmission you have into it, or find a complete '92 - '93 Integra RS/LS transmission.
Old Dec 1, 2015 | 10:08 PM
Jake644's Avatar
i am currently rebuilding a ys1 cable trans i have two of everything. if you would be interested I have a extra case that i am currently repairing where the previous owner poked a hole in it with a spider gear.
Old Dec 1, 2015 | 10:54 PM
king06's Avatar
Where are you located? I have a big spline cable case taking up space in my garage. Will never need it. Pm me
90efcvicsi23
Dec 4, 2008 10:19 PM
lilo_goki
Apr 20, 2007 11:25 PM
jdmcrx90
May 2, 2005 02:40 PM
jdmIScool
Aug 21, 2002 07:18 PM
dustin
Apr 1, 2002 11:15 AM
