Integra Runs super rich
Old Nov 18, 2015 | 12:34 PM
Tegraracer90's Avatar
Default Integra Runs super rich
Got a 95 Integra LS with its stock B18B motor, 270K on bottom end of motor, about 30K on top end since it broke a valve and I put a rebuilt head on it.
It runs super pig rich and I cant figure out why....so far I have done this to try and correct the problem...
*New Oxygen Sensor
*Rebuilt OEM Fuel Injectors
*New Mass Air Flow sensor
*New throttle Position sensor
*New PCV valve
*New Cap, Rotor and Plugs (mainly just cause it needed them)
*Checked both mechanical timing and ignition timing.
I wash the car and within a week the whole rear of the car is covered in black soot, coworkers who drive behind me say every time I shift it dumps black smoke like a diesel. It will barely idle when cold when I first start it...and sometimes even quits as soon as I push the clutch in at a stop sign or traffic light....
I just dont know what to look at anymore....anyone else got any ideas
Old Nov 18, 2015 | 01:36 PM
B_Swapped93's Avatar
Default Re: Integra Runs super rich
make sure the little o-ring is there/not crumpled for the MAP(not maf). stock ecu I trust.
Old Nov 18, 2015 | 07:28 PM
wunfstgsr's Avatar
Loved
Community Favorite
Clean and check the o ring on the IACV and make sure its pluged in and or no pinched wires.
Also sounds like ECT sensor is bad. check that sensor and any codes in the ecu.
Old Nov 19, 2015 | 08:16 AM
Tight-R's Avatar
I would check the compression, that sounds like worn out motor to me. Black soot is usually caused by oil burning, not fuel burning. A lot of ITR owners can attest to this.
Old Nov 20, 2015 | 12:55 AM
bigtimegambler's Avatar
Make sure you're not actually consuming oil first.
Old Nov 20, 2015 | 04:25 AM
Tight-R's Avatar
270,000 mile bottom end... it burns oil.
Old Nov 20, 2015 | 05:03 AM
K20.ek's Avatar
If u just slapped on the rebuilt head did you check ur valve lash?
fattysDA91
Nov 12, 2013 10:20 AM
LinkJ
Honda CR-V & Element
13
Jan 11, 2013 12:35 AM
Bowl_of_Rice
Jun 17, 2011 09:23 PM
oldSCHOOLhonda
Apr 15, 2005 10:19 AM
ironchef25
Apr 12, 2004 07:28 PM
