Built b16a head stock block outputs?
Who has dyno results of built or fully built b16a head with stock b16a block? I want to see how much power that would yield for a built head only. My b16a2 has about 175,xxx miles. In the future I plan on getting Skunk2 high compression valves, Stage 2 tuner 2 camshaft, cam gears, and high compression head gasket. With that my compression ratio should go from 10:2 to 10:6 - 10:8. It's too expensive to built both block and head so I'll built the head first and block in far future.
