DX EKcivic swap WIRING QUESTION please help
Old Nov 17, 2015 | 05:48 AM
David_ej6's Avatar
Default b18c DX EKcivic swap WIRING QUESTION please help
This is for a JDM b18c gsr engine i am putting in my ek coupe its a dx model
...After doing research i have found that if you are using the STOCK wiring harness(from d16y7) you will need to do some modifications like the 3 wire to 2 wire and pressure switch and the TPS...
...My question is: If i Have the ECU and Harness for my gsr swap does any of this really matter?????? please help thanks in advance!
Old Nov 17, 2015 | 08:04 AM
David_ej6's Avatar
Default Re: DX EKcivic swap WIRING QUESTION please help
bump
Old Nov 18, 2015 | 04:23 AM
David_ej6's Avatar
bump
Old Nov 18, 2015 | 02:55 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/honda-civic-d...-vtec-2987229/
Old Nov 19, 2015 | 05:08 AM
David_ej6's Avatar
thanks but did not find my answer my question
Old Nov 20, 2015 | 02:35 AM
Technical Hero
You can't use the GSR harness. Its a two piece as opposed to the Civic's one piece. You'll have to either use your harness and make the adaptations in the link above or use an EX harness from your corresponding years Civic and make the necessary additions.
Old Nov 23, 2015 | 04:25 AM
David_ej6's Avatar
oh thanks man i see now. So the ex harness will delete the procedures I will have to do with the dx harness?
b18cknight
Jan 11, 2011 04:29 AM
gsr336
Feb 28, 2007 07:33 AM
lrcrx90
May 29, 2006 08:14 PM
Myh4tch
Jun 14, 2005 06:56 PM
sydag5
Jul 2, 2002 02:48 PM
