FS Lenged 2 piston calipers milled T23 Brackets/4x100& Stainless steel brake lines!
Hey HT whats up!?
I have for sale 2 piston Acura Legend calipers with redrilled 4x100 Vtec Prelude rotors and a pair of stainless steel brake lines which came off of my civic. The brakes ran fine. Just got them resurfaced a couple weeks before taking them off. you can still see the light machining marks (i can clean the rotors if you insist, they rust up so quick, even while u wash the car)
upgrade your brakes with this OEM set up!
Acura legend 2 Piston Calipers
T23 Brackets milled down to fit civic / integras
Prelude Vtec Rotors drilled to 4x100
Technafit Stainless Steel Brake lines w/ red plastic coating
price:$260 + buyer pays shipping
only a couple pics if u need more please text me
562;33four2697
Legend Calipers + 4x100 Prelude Rotors vs 2000 civic Ex stock brake set up
562;33four2697
brake calipers look different? one single piston and a legend 2 piston??
is that correct?
man it looks confusing.. are you comparing this last pic, to show difference in size?
is that correct?
Rotors are both redrilled, but different sizes.. Looks very odd. But the post states they are civic ex brakes to compare.
Alan
Alan
If u look,their not both redrilled,the smaller rotors are stock with the 2 holes to hold the rotor on the hub and 2 holes for the screws to remove the rotor, nice setup glws
Running mismatched brake setups...How sad is that?
Unless you're trying to show the difference between the legend and civic setups... In that case, you should probably post a picture of both legend brake setups together in one picture.
Pretty sure he comparing when it says "legend calipers and prelude rotors vs stock civic ex"
So much confusion over a simple brake set up. Legend calipers with milled brackets and redrilled rotors for the listed price. The cross drilled rotor is an example to compare EX brakes which are larger than DX brakes. Someone just buy this good oem set up and call it a day.
ek9kbomb'd, I see the rotors now. My eyes were playing tricks.
Alan
Alan
Funny how you can type but haven't figured out how to read yet...How sad is that?
try again with less suck before shitting on peoples thread
Legend Calipers + 4x100 Prelude Rotors VS 2000 civic Ex stock brake set up as stated by the op in the original post and @ $260 not a horrible deal either
jonesEK
Jan 27, 2016 08:57 PM
1998GsRIntegra
Jan 2, 2012 07:25 PM
