91 Civic - wiring fuel injectors
Old Nov 11, 2015 | 06:14 PM
Joe Yaerrd's Avatar
Default 91 Civic - wiring fuel injectors
OK so I'm doing mpfi swap 91 sedan I have 0bd1 injectors. ...I've read that you're supposed to pin the wires that would go to the resistor to a15. .cut solder To wire but what about the wire you cut does it need to be taped off or solder them together
Old Nov 12, 2015 | 10:47 AM
hondamark35's Avatar
Default re: 91 Civic - wiring fuel injectors
all of the yellow with black (or black... whichever wires are the same color between the four injector leads) are the 12v supply and should be joined together in some fashion. solder, junction connector...
the multicolor wires (different color for each injector, normally blue, red brown and yellow) go the the "A" connector on the ECU pins 1, 3, 4, 5... IIRC. The ECU grounds these sequentially to operated the injectors.
Old Nov 13, 2015 | 07:55 AM
Joe Yaerrd's Avatar
Hey man thanks a lot one more question running 0bd0 can I use a 0bd1 iacv .will the plugs be the same
Old Nov 13, 2015 | 10:02 AM
Joe Yaerrd's Avatar
Sorry I'm a newb
Old Nov 13, 2015 | 04:50 PM
v4lu3s's Avatar
RTFM
The iacv needs to match the manifold. If your manifold is obd1 then it will fit.
beatthisspeed69
Apr 25, 2007 05:33 PM
payneth
Mar 17, 2006 08:30 PM
turbo_ef9
Jan 24, 2005 09:47 AM
schwett
Dec 30, 2003 01:38 PM
Blaze45
Sep 23, 2003 11:43 AM
