96 A/C compressor. Help!
Old Nov 10, 2015 | 07:02 PM
Doms's Avatar
Default 96 A/C compressor. Help!
So my A/C compressor is broken and I wanted to know if it's possible just to take the ac compressor out and run a shorter belt. That was made for an older vehicle without an ac compressor. And just run it to my altenator. Would this work?& Would my car be able to run without the part... Not quite sure.
Old Nov 10, 2015 | 07:41 PM
tim73's Avatar
Default Re: 96 A/C compressor. Help!
If you can find the correct belt, you don't need the compressor
Old Nov 10, 2015 | 08:41 PM
hometheaterman's Avatar
Exactly. If you can find the correct size belt you can bypass the compressor. Or you can get one of these by pass pulleys and run the correct belt. Either one will work, but getting a by pass pulley may be easier.
1994-2001 Honda Accord A/C Compressor By Pass Pulley - Dorman 34168 - - PartsGeek.com
Old Nov 10, 2015 | 10:23 PM
holmesnmanny's Avatar
It's likely depending on what car you have you can get an alternator belt for a dx model.
chieftaco
10
Oct 11, 2009 03:38 PM
SuM Honda
Oct 6, 2008 08:40 PM
sohcSUCKS
Dec 9, 2007 12:43 AM
floriudabrain
Jan 31, 2006 07:04 AM
wizards581
Oct 23, 2004 12:20 PM
