99 Teg R
Old Nov 10, 2015 | 09:17 AM
andymccauley's Avatar
Default 99 Teg R
Well I'll start by saying this isn't my car nor do I have any knowledge of Honda related cars.
But anyway my buddy has a 99 Type R that he turboed, had tuned and "blew" up the motor. It sat for a few years outside, and is now in my garage.
My role in this is pulling the motor, taking it apart and replacing hopefully only the block. The motor is already out and I'm procrastinating on taking it apart. Might start tonight. Here is some proof lol
Old Nov 11, 2015 | 08:01 AM
94rs-turbo's Avatar
Default Re: 99 Teg R
are you in the UK? Don't have 99 ITR's in the US. GL on the rebuild
Old Nov 11, 2015 | 08:17 AM
2000FBPITR's Avatar
I believe Canada had 1999 ITRs
Old Nov 11, 2015 | 09:31 AM
itr#1334's Avatar
Yes, but no in black. OP post more pictures!
Old Nov 11, 2015 | 11:57 AM
RTW DC2R's Avatar
you dont have any knowledge of Hondas but you are tasked with pulling the motor and rebuilding it? I remember those days haha
good luck with the rebuild.
Old Nov 12, 2015 | 04:06 PM
Interesting, build date is 12/99 on the door jam. Could just have type R stuff swapped on it. I'm more of a old VW/Mazda guy myself Honda has never really attracted me.
Anyway onto some more tear down and carnage.
The culprit, cracked #4 sleeve.
Old Nov 13, 2015 | 08:05 AM
Todd00's Avatar
I said I don't want a title!
That would be a MY 2000 if it's dated 12/99. Think about it
Old Dec 6, 2015 | 01:26 PM
Here it is the replacement. All 2700 dollhairs worth (not my money).
Old Jan 17, 2016 | 01:49 PM
Started swapping some things over to the new motor, waiting on a clutch, resurfaced flywheel, and some gaskets still.
Still need to drill and tap a hole in the block for the knock sensor since the B18A that is going in it doesn't have one stock.
Old Jan 25, 2016 | 03:52 AM
Pretty much ready to drop in, just waiting on a clutch, resurfaced flywheel, and some gaskets.
Relocation of the knock sensor in the B18A block since it didn't have one.
Turbo drain
Old Jan 25, 2016 | 06:22 AM
B16EJ's Avatar
Nice bike. I have a 99 itr also I'm interested to know if it's another Canadian itr, which are few and far between unfortunately.
I'm pretty certain they only came in CW in 99 but I could be wrong, out the car could have been sprayed black the paint looks fresh for 99. Anyways there's allot of easy ways to tell. The quickest way to tell by looking under the hood is to look in the corner where the abs motor sits, behind the abs bracket if there is a circle hole or a hole with a plastic tube feeding air then it's not a type r. Type r's have the stamping for the circular hole but it's not cut out.
Old Jan 25, 2016 | 07:15 AM
97CWITR's Avatar
Turbo drain lines with a 90 degree bend using fittings like that scare me. Use a 45 degree -an line to another 45 line and never have a problem.
Old Jan 25, 2016 | 07:40 AM
white rocket's Avatar
OP mentions the door sticker saying 12/99 meaning that it's a 00MY
Old Jan 25, 2016 | 10:21 AM
RTW DC2R's Avatar
Why is the owner going with a B18A? Maybe its just me but this thread is so strange haha
Old Jan 28, 2016 | 10:54 AM
DC2888's Avatar
Cheaper than buying a B18C5. Hes doing LS/Vtec turbo.
Old Feb 7, 2016 | 06:44 AM
He just wants to make power with it. It's got a bunch of aftermarket stuff in the block. Low comp pistons, eagle rods, some sleeve protection insert, built head.
And as for the turbo drain. I would like to use a 45 but the pan is already tapped with some funky 5/8 pipe fitting thing.
Your right this thread is wierd lol. It's not my car and it's been in my garage for 3 months. I want my garage back! Lol
Old Apr 19, 2016 | 07:01 AM
So I didn't finish it completely but it was very close to being done before it left my house.
A lil back story on the car, he has had it for 6 years the previous owner had it stolen and stripped which is why the front fenders and hood are different but color matched, the original B18C5 cracked a ring and was sold, so a B18C1 was dropped in and shortly after turboed. That motor obviously met it's end.
The car is now at a shop being dyno tuned and getting the motor broken in before he gets his hands on it.
Old Apr 19, 2016 | 07:25 AM
tony_2018's Avatar
Fish Twig
Dude like wtf, if you're not going to build the block why over boost a stock motor. Waste of time and money to just keep replacing the block again and again.
That was directed the owner of that teg, not the OP.
Old Apr 19, 2016 | 03:57 PM
This one is built, not by him or me though. He bought it off of a guy that had a speed shop build him it and never ended up putting it in anything. Built for boost, I don't think the B18C1 that blew while boosting was ever really planned for boost to be added, idk though I wasn't there
dayaftertomorrow
May 8, 2006 08:08 PM
itr0032
Jun 21, 2003 11:35 AM
