Honda CR-V & Element 2WD & 4WD Element & CR-V
2012 CR-V Heat isn't hot
Old Nov 9, 2015 | 11:24 AM
kristi1989's Avatar
Icon4 2012 CR-V Heat isn't hot
Hi!
I am a first time Honda owner, just purchased a 2012 CR-V last week. Today I noticed that when I turn on the heat, it doesn't get hot at all. On my 45 minute commute this morning the air blowing out was barely lukewarm. The temperature was set to the hottest setting, and the blower was also set to the max.
Since the car is still under a 1 month warranty with the dealer, I have made an appointment for Wednesday for them to fix this. It's starting to get cold here and I NEED to have heat in the car.
Is this a common problem with this car, and what is the fix for it? I don't know much about cars and wouldn't even know where to begin as far as figuring out what the problem is.
Thanks!!
-Kristi
Old Nov 9, 2015 | 05:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2012 CR-V Heat isn't hot
The heater core may be partially clogged. See this service bulletin:
File Type: pdf
Old Nov 9, 2015 | 05:31 PM
kristi1989's Avatar
Thank you so much!
Old Dec 17, 2015 | 05:27 PM
Rdonovan's Avatar
Did you get the heating fixed? Kristi1989, what was the problem with your heater, the heating core or thermostat? My co-worker's Honda Element is doing the same thing.
Old Dec 18, 2015 | 10:51 AM
kristi1989's Avatar
They flushed the heater core, and everything has worked fine since then. It was a known problem and it took them a day to flush it.
Cimburke23
40
Feb 12, 2011 11:48 AM
ninjaturtleEG
Jan 15, 2010 11:21 AM
KayTran
Dec 16, 2008 12:06 PM
rbhambha
Sep 7, 2008 07:19 PM
Downs
Dec 7, 2005 03:37 PM
