OR 97 HONDA CIVIC EX W/ TONS OF WORKS DONE
Hey Honda-tech members,
I’m selling my 1997 Honda Civic EX coupe “CLEAN TITLE”, 5-speed manual transmission, that shift like butter clutch. It has 166k miles(still use as a daily driver go to school and back), with the D16y8 VTEC motor. The tags are good thru 2017 (just renew). A/C, power window, power locks, power sunroof, and power side mirrors are works properly. It has a 95% threads on the low profile tires all around. I would say the interior has an amazing shape (9 out of 10) and the exterior is very glossy and shiny (8 out of 10). Does not have leak or burn any oil or fluids.
I have a lots of work done and parts replace:
Resurfaced and hot tanked head
Camshaft and camshaft seal
Rocker arms
Valves vacuum tested great
Head gasket
Water pump
Timing belt and timing belt tensioner
Head bolts
Exhaust header gasket
Fuel pump
Main relay
Fuel pressure regulator
Fuel pump bag
Radiator
Power steering belt
Alternator belt
All 4 injectors
Brake master cylinder
All fluids flushed
Fresh gear oil
All iridium spark plugs
Spark plugs wires
Distributor cap and rotor
Thermostat
Air Filter
Distributor gasket
Valve cover gasket and O-rings
Fuel filter
Axel
Ignition control module
All the works has been done since 5k miles on it, and it run fantastic. I replaced it all with 100% OEM original honda parts, nothing aftermarket other than the rims and muffler. I have been daily driving this car and had no problems. I decided to take the liberty of replacing all that before I sell it to give it a better value, and to sell someone a car that has as much reliability as a new car, as well as having the most power for the motor. So, that’s why I did all that works, it’s just a regular maintenance after a certain amount of miles. I also do changing the oil over 2500 miles.
Besides all the pros that the cars has, there are some cons on the car to:
Crack windshield
A/C need to be recharge (I haven’t do it because this is winter and I need heater rather than a cold A/C)
Alignment
A bit of hesitation on acceleration (it just appear when the first 5-10 minutes driving and it comes randomly, but once you finished with the hesitation, it will never happen again until the rest of your journey. I can’t figure it out by myself)
The reason I selling this car is because I don’t needed anymore.
Serious buyer only! (PM me if you are interested and I’ll give you my contact information)
Cash in hand before we meet or test drive
Asking for $3500 OBO
I will give the pictures by email, because I can't post it all.
Rocker arms
Head gasket
Water pump
Head bolts
Fuel pump
Main relay
Fuel pump bag
Radiator
Power steering belt
Alternator belt
All 4 injectors
All fluids flushed
Fresh gear oil
Spark plugs wires
Thermostat
Air Filter
Distributor gasket
Fuel filter
Axel
Crack windshield
Alignment
Bix VT
13
Nov 5, 2012 08:35 AM
civic duty
Mid-Atlantic (Sales)
Aug 3, 2011 03:56 PM
