Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Ride height question
Old Nov 7, 2015 | 04:49 PM
Peabody's Avatar
Default Ride height question
I need help to figure out what's up with this ride height.
I replaced the rear original shocks with Sensen shocks (tight budget).
I reused the original springs since they appear in good condition.
It does need wheel alignment, but is that the 'silver bullet' to fix the ride height?
If its saggy springs, wouldn't the rear drop instead of this?
Thanks
Old Nov 8, 2015 | 06:00 AM
toyomatt84's Avatar
Sanji
Default Re: Ride height question
Are you sure the spring is seated properly on the new dampers? Also, what model vehicle did you buy these dampers for?
Old Nov 8, 2015 | 05:32 PM
Peabody's Avatar
Yeah they are fitted in correctly (the spring end where there's a small notch on the bottom plate of the shock/damper).
I checked a few different websites to ensure i ordered the right shocks for the car.
Old Nov 8, 2015 | 06:56 PM
toyomatt84's Avatar
Sanji
Well, the coupes and hatchbacks both had different rear dampers. So, being that you went with a bargain damper, you may have one that is considered to be "universal" for the chassis, when in fact its not.
Old Nov 9, 2015 | 04:40 AM
solex's Avatar
If the dampers have removable spring seats, you may have installed them upside down. I have done this before and had the same problem...
Old Nov 12, 2015 | 01:51 PM
dustinhxc's Avatar
Hmm thats interesting.. I decided to go with struts and springs so the ride height matched for rear and front. Good luck man.
Old Dec 2, 2015 | 06:51 PM
Peabody's Avatar
I did some cross reference research before ordering them. I did a visual inspection before installing. One rod on the strut was slightly longer (3/8") but that wouldn't affect it since the weight of the car are compressed evenly.
I disgarded the hard plastic seat that came with the stock struts because they won't fit with Sensen struts. So it's not that.
Old Mar 19, 2016 | 04:38 PM
Peabody's Avatar
I installed stock coilovers (i got from a junkyard), and the ride height is normal again.
Overall length is the same between Sensen and the stock.
Robstunner4
Suspension & Brakes
Oct 8, 2006 09:22 AM
burnerak47
Mar 7, 2005 11:51 AM
tianporn
Nov 30, 2004 08:55 PM
ryan12321
Sep 3, 2002 04:33 PM
fiebru1119
Apr 25, 2002 11:26 AM
