em2 speedometer inop
i have a 2004 civic manual trans the speedo has been stuck at zero for some time now i replaced VSS and it did not fix the problem check engine light on any one got n e ideas
What is the code for the CEL?
Check fuse for the gauge assembly. Check connections at back of gauge assembly, an open in the wire from GA to PCM, a short to ground, bent/loose or corroded terminals, a faulty PCM or gauge assembly.
gorillapno
May 26, 2008 09:38 PM
joethejoeman
Jan 18, 2007 04:50 PM
