Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2003 Honda Accord EX v6 Valve Adjustment
Old Nov 5, 2015 | 07:34 AM
Dragomir's Avatar
Default 2003 Honda Accord EX v6 Valve Adjustment
The check engine light on my wife's Accord has been coming intermittently lately, and we dropped it off last night at a mechanic who we have never had any issues with in the past. This morning we received the following diagnostic:
MY NAME IS DYLAN I AM THE SERVICE MANAGER HERE AT GASTONS GARAGE AND I AM EMAILING YOU WITH WHAT WE HAVE FOUND OUT WITH YOUR HONDA.....WITH FOLLOWING OUR DIAGNOSTIC PROCEDURES WE NEED TO DO A VALVE ADJUSTMENT. ACCORDING TO HONDA THE EXHAUST VALVES TEND TO TIGHTEN UP AFTER A PERIOD OF TIME AND DO NOT ALLOW ALL OF THE EXHAUST TO BE RELEASED FROM THE ENGINE CAUSING A RICH CODE AND CONDITION IN YOU VEHICLE.ALSO WE NEED TO PUT MORE FUEL IN THE VEHICLE TO DO AN ADEQUATE TEST DRIVE.. TO START WITH ALL OF THIS YOU WILL BE LOOKING AT A COST OF $685 TO START. FEEL FREE TO EITHER CALL OR EMAIL ME BACK AS SOON AS YOU CAN PLEASE
Looking online, this doesn't look like something particularly easy to do ourselves, but it also seems overpriced. Does anyone else have experience with this issue and how much it should cost?
Thanks.
Old Nov 10, 2015 | 09:09 AM
jimlaw3's Avatar
Default Re: 2003 Honda Accord EX v6 Valve Adjustment
what code did you have?
Old Nov 10, 2015 | 09:21 AM
Dragomir's Avatar
Codes were 172 and 175, fuel banks 1 and 2 too rich.
Old Nov 10, 2015 | 09:27 AM
jimlaw3's Avatar
how long has the light been on
Old Nov 10, 2015 | 09:47 AM
jimlaw3's Avatar
Would need to check MAP sensor reading ,should be under .95v if it is not most likely have a leak at the egr valve or even purge control valve, I find it hard to believe that all valves are tight at the same time on both banks,also could check short term fuel trims on both banks to see how rich its running.
Old Nov 10, 2015 | 11:13 AM
Dragomir's Avatar
It first came on about a week and a half ago. She put in some fuel injector cleaner based on online suggestions and it went away for a day or so, then came back off and on, mostly on, for the next couple of days. We are borrowing another vehicle for the time being and she is not driving hers. At that cost, we would be better off trading her car in towards a new one.
When I asked about things they had checked, they responded:
WE HAVE CHECKED FUEL PRESSURE AND MASS AIR FLOW RESPONSE AND READINGS.. WE HAVE ALSO CHECKED THE READINGS COMING FROM THE OXYGEN SENSORS WHICH ALL SEEM TO BE RESPONDING PROPERLY BUT READING RICH AS WE EXPECT WITH THE CODES THAT ARE IN THE SYSTEM UNFORTUNATELY IN OUR DIAGNOSTIC PROCEDURES THIS [valves] IS THE ONLY THING LEFT TO CHECK AND DO FOR US TO EVEN BE ABLE TO MOVE ANY FURTHER.
Old Nov 10, 2015 | 12:41 PM
jimlaw3's Avatar
how many miles is on your car?
Old Nov 10, 2015 | 12:44 PM
jimlaw3's Avatar
make sure air intake tube is not cracked also.
Old Nov 10, 2015 | 01:13 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Thanks.
The price is about right for that job,and tight valves ARE a common problem,however the diagnosis is at fault, find anther shop. Tight valves will not cause a rich condition,but in fact will cause the opposite, a lean condition.
Originally Posted by jimlaw3
...I find it hard to believe that all valves are tight at the same time on both banks...
Dont work on a lot of Hondas,do you?
Old Nov 10, 2015 | 01:14 PM
jimlaw3's Avatar
I work on Hondas everyday
Old Nov 10, 2015 | 01:18 PM
jimlaw3's Avatar
Tight valves can cause rich condition because the incomplete combustion sending raw unburnt fuel to the AF sensors ,therefore throwing a rich code.
Old Nov 10, 2015 | 02:37 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Apparently not.
LoL, thats not how it works son. Time to take a class or two.....
Old Nov 10, 2015 | 02:57 PM
jimlaw3's Avatar
douchbag
Old Nov 10, 2015 | 03:13 PM
jimlaw3's Avatar
peace out all !!!! leaving this unfriendly forum.Good luck !!!!
w002mia
Jan 15, 2013 12:41 AM
1ATony
Jan 28, 2011 08:05 AM
pauken
Feb 13, 2009 09:32 AM
Jack42038
Classic Hondas
10
Jan 8, 2009 10:33 AM
necoris
Mar 31, 2004 08:20 AM
