Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Engine dies as soon as you put it in drive
Old Nov 4, 2015 | 07:39 AM
speedfreek09's Avatar
Default Engine dies as soon as you put it in drive
2001 civic, just like the title says will run in park, reverse, and neutral, but when shifted into drive it will either run horribly or die immediately. Honestly don't know where to start.
Old Nov 5, 2015 | 06:18 AM
NDNV's Avatar
Default Re: Engine dies as soon as you put it in drive
Any codes? Is the CEL on? Is the D light blinking?
Check the level of ATF.
Check the ignition switch as they are known to go bad on this gen Civic.
Old Nov 10, 2015 | 06:20 PM
Atf level is good, replaced computer, transponder, ignition switch, key cylinder, and entire throttle body. Starting to think it's crank or cam position sensor. Still does the same thing but I've noticed it flutters when switching back and forth between park/reverse/neutral/and drive. It stayed running for longer when I replaced the components.
Old Nov 11, 2015 | 08:48 AM
Fixed, finally got it to pop a code, crank position sensor. unplugged it and ran better, and didnt shut off
Old Oct 4, 2024 | 08:53 AM
oherrera98's Avatar
hey brotha, I'm having the same issues with my Honda, it bogs out on reverse and drive. To turn it on i have to give it some gas but will stay on after no problem. It began when I was going up a hill the engine bogged out and died. Paid $400 for a tow. Do you think this sensor from Amazon will work?
Standard Motor Products PC477T Crankshaft Position Sensor https://a.co/d/j2YpPWe
sheeliboy
Mar 22, 2015 01:28 PM
puppet_828
Dec 7, 2012 12:27 PM
delmo777
Oct 17, 2012 03:30 AM
pityocamptes
12
Dec 14, 2011 09:48 AM
C_Rock77
Sep 13, 2009 04:41 PM
