B18c5 Gasket Set codes?
When it comes to the b18c5, do the b18c1 and b16a2 match up also?
Is there a part number that will narrow down all the gasket and seals I will need? I tried to search but I'm running into other people saying one thing then another.
I'll need all the gaskets for top and bottom.
Pretty much all i need now is the gasket/seals + clutch then I'm done.
B18c5 Swap
Jun 3 Cams
B18c5 Trans
Bored to 81.5mm
RS Pistons
ARP Rod bolts
Head complete rebuilt
B18c5 Swap
Jun 3 Cams
B18c5 Trans
Bored to 81.5mm
RS Pistons
ARP Rod bolts
You should be able to find what you need on the various online parts sites.
refer to here https://honda-tech.com/acura-integra...parts-3254853/
B18c5 Swap
Jun 3 Cams
B18c5 Trans
Bored to 81.5mm
RS Pistons
ARP Rod bolts
B18c5 Swap
Jun 3 Cams
B18c5 Trans
Bored to 81.5mm
RS Pistons
ARP Rod bolts
sacjdmz
Oct 18, 2006 09:10 PM
