Poor mans type r b16 stock valves with skunk 2 valve springs and skunk2 tuner stage 1
Old Nov 2, 2015 | 12:23 AM
Gsrmemo's Avatar
Post Poor mans type r b16 stock valves with skunk 2 valve springs and skunk2 tuner stage 1
Hi I am building a Poors man type r b16 head with b18c block I had a few questions I plan on running stock valves with alpha series dual springs and titanium retainers any feedback I also plan on using stock keepers and skunk2 tuner stage 1 cams
Thanks for the help
Stock bottom block
Arp head studs
Cometic head gasket
Skunk2 tuner cams
Skunk2 intake
4-2-1 tri y headers
Old Nov 2, 2015 | 06:56 AM
93egSLEEPER's Avatar
Default Re: Poor mans type r b16 stock valves with skunk 2 valve springs and skunk2 tuner sta
Are you asking a question?
"Poormans R" use Type r pistons in a GSR block. You simply just have a low compression JDM GSR at this point.
Old Nov 2, 2015 | 06:13 PM
Gsrmemo's Avatar
Yea that's actually what I am planning on doing a low comp gsr for future turbo but my question was can I use dual valve springs with stock valves and be fine also use my oem keepers
Old Nov 2, 2015 | 06:19 PM
Maluko's Avatar
Yes that will work
Old Nov 2, 2015 | 08:49 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yea you will be fine, Tuner 1 are about the same as CTR cams, I made 200 WHP on those cams on a very mild ITR engine. They felt good with good low and mid.
But if your going to turbo id look into just using a cam that would work better with that like even maybe oem gsr cams i hear they work well on turbo applications.
Old Nov 2, 2015 | 10:03 PM
Gsrmemo's Avatar
Icon5 Re: Poor mans type r b16 stock valves with skunk 2 valve springs and skunk2 tuner sta
I was also going to get alpha series standard compression valves any feed back on those any one
Old Nov 2, 2015 | 10:56 PM
wunfstgsr's Avatar
Loved
Community Favorite
No need for them there a waist imo when OEM valves work just fine unless you go flat face for a bump in comp.
Old Nov 3, 2015 | 06:33 AM
ITR/CTR cams work well in turbo apps as well. The Tuner 1's wouldn't hurt. Little bit hotter VTEC will get that power band up quick under boost.
Old Nov 3, 2015 | 08:43 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yea i agree they would work quite well but my point or what i meant was maybe if he diddnt purchase the cams yet he could save some $ and find oem gsr cams cause there very cheap and he could save some $ towards another mod. I mean i payed i think around $600 for my Tuner 1's and sold them for i think half that. I seen GSR cams for as little as $50.
Old Nov 3, 2015 | 11:05 PM
^^^^ very true sir. Very true
Old Nov 4, 2015 | 08:22 PM
vtecmaster85's Avatar
OP could also keep tuner 1 intake and use type r or gsr exhaust cam.
Old Nov 4, 2015 | 08:53 PM
wunfstgsr's Avatar
Loved
Community Favorite
if im not mistaken thats a good combo for a JRSC setup, i had something similar, I had 2001 spec ITR intake and GSR ex. when i had my JRSC setup a few years ago.
Turbo setup just stick with both GSR cams, harder to sell just one cam down the road.
StreetLethaleg6
17
Aug 13, 2010 11:04 AM
insidiouseg-6
15
Apr 22, 2008 08:29 PM
Speed_1
Aug 3, 2006 01:13 PM
1hotintegra
Apr 7, 2004 10:02 AM
B16Anees
19
Oct 30, 2003 02:14 PM
