I'll update this with more details/pictures hopefully this weekend. For people that only read the first few lines of a for sale ad, if you are looking for a numbers matching, single owner, 97 ITR unicorn then this car isn't for you.
If you are looking for a 97 ITR that has a NON-SALVAGE title, and has been basically restored with as many new OEM parts, as well as a mix of performance related parts then this car might be for you.
Asking price for the car is 16k OBO. The car is located in the Northern Virginia area (20 minutes outside of DC).
Some of the pictures maybe broken due to image hosts, but it'll give you a general idea of what was done to the car. Like I said, detailed pictures will be taken soon and posted up here.
Below is a general list of modifications/etc that I can remember off the top of my head. I've also included a few small issues (just things that need to be taken care of) for full disclosure to any potential buyers.
Engine
R-Dot Shortblock, ~11k miles
97 B18C5 head – valve guides, seals, valve job all performed by Hoffman Automotive Machine
JDM ITR Trans (4.7 FD)
Fizanda Lightweight Flywheel + Exedy Organic Clutch/Pressure Plate (New)
Fluidyne Aluminum Radiator + Slim Fan
PLM Toda 4-2-1 Replica Header (New)
JDM ITR Exhaust + B-Pipe
ITR Intake Arm + Airbox (New filter)
Wire-Worx Engine Harness, Stock Routing (New)
Samco Radiator Hoses (New)
HAsport Mounts
Skunk2 Lost Motion Assemblies (New)
Suspension
PIC Select R3 Coilovers (12k/14k)
Buddy Club Front/Rear Camber Adjusters
PCI Spherical Rear Trailing Arm Bushings
OEM Honda Toe Arm (New)
Exterior
Spoon replica mirrors – color matched NH-0 with black base plates (Stock Mirrors Included)
JDM SIR-G Corner Lenses
OEM Red Acura emblems (New)
JDM Window Visors (not installed, but included)
Wheels/Tires
Dunlop Direzza ZII – 205/50/15 (Less than 100 miles on them)
15*7 Kosei K1 (38 offset) – wheels were sandblasted, reconditioned and then powder coated white
Brakes
OEM ITR Calipers rebuilt with OEM Honda Seals (Rebuilt and then Zinc Plated by RaceLine USA)
Hawk HPS Brake Pads
OEM Honda ITR Master Cylinder (New)
ATE Superblue Brake Fluid
Extras
OEM ITR Car Cover + Bag
Notes
New timing belt, waterpump done at the time of motor install
Entire car has been PDR’d (Paintless Dent Removal)
Wheel wells/undercarriage have been stripped of the factory undercoating, and painted over with POR-15 White-Cote (UV Stable)
Bodywork included the following new items from Honda, all items then painted at D&V Autobody
o Front Bumper, Front Lip
o Radiator Support
o Wheelhouse Piece
All suspension pieces have been sandblasted and powdercoated gloss black by Figure Finishing
All hardware has either been zinc plated or purchase new from the dealer
New Front and Rear Hubs (New from Honda)
About 90% of bushings replaced with HardRace bushings. The rest with OEM Honda
Full Interior
Spare Kosei K1 replica stickers (looks more authentic than what’s on the wheels now)
No A/C
Power Steering is looped
Brand new OEM Honda Fender Liners + All new OEM Hardware for bumpers, etc
Issues
Small ding/dent above the quarter panel that was unable to be removed by PDR
Small exhaust leak where axle back meets B-pipe – The nut on the B-pipe needs to be cut or re-tapped
Using a JDM ITR ECU – check with your local emissions if you will pass. No emissions where I live so it’s easy
The ABS sensors are not installed at this time – Will provide to buyer to install
No engine torque mounts installed – I have most of the pieces, just wanted to powder coat them
10/11/15 - Update: Pictures below along with links to full albums
ALL VIN # matches (doors, hood, trunk, frame, engine, etc.). NO accidents. Car was originally from Canada so it has daytime running light (DRL) and the odometer is in KM. It has 122,000+ KM which converts to 75807 MILES. Has no AC but it does have heat and power steering. Canadian Type R has AC as optional which this one did not come with. Car is PAID OFF and has NO lien. Car title is CLEAN. I pulled a autocheck report and will have it available.
PARTS:
Mugen 4-1 JDM Header
PasswordJDM Carbon Fiber Intake
Fujitsubo RM-01A Exhaust
SMSP Cat with Cel fix
Spoon Rear Strut Bar
16" Enkei ES Tarmac 16x7 +45 wheels
Alpine Headunit
Antenna Delete (still have radio)
ALL ORIGINAL!
NO A/C! Yes, there is heat. AC is optional for Canadian vehicle.
Has Power Steering
New Clutch install
New Clutch Master Cylinder
New Slave Cylinder
New Shift Linkage and bushing
New Rear Tail Light Gasket
New K-TUNED PRO CIRCUIT Shifter
New Koni + Ground Control Coilover
New Tires
New Strut King pedals (Type Rx pedal style)
New Viper Alarm
OIL change every 3-4k Miles
Fully Professional Detail about a month ago
ASK me for VIN and Badge Number.
Re: Cars For Sale: Integra TYPE-R's - Nov/Dec 2015
2000 BLACK ITR SHELL (Toronto, Ontario, Canada) - $4500 USD
*Had this project car back in 2006 and been sitting since. Finally got the time to get it going but changed my mind.
*This is a rare color in Canada as Canada never had Black ITRs. I believe its the only Black ITR in Canada right now (I am not aware of any other ones)
*This car was originally from Florida (Theft Recovery) missing motor/seats/suspension/bumpers/lights with a (Junk/Irrepairable Title). It was imported into Ontario, Canada and now has a clean title (Canadian Ownership)
*The mileage is unknown, but its very cleans with no rust at all. Has a few dings and dents but no damage anywhere.
*JDM HID Front end complete (Headlights/bumper/Grill not shown in pic)
*Rear bumper and taillights included.
*Complete interior minus Front and Rear seats. Has all the panels and carpet
*Stock shocks/springs with 5 Bolt included
*A bit dirty from sitting around but will be cleaned up before sold
*Fresh painted bay. Bracket deleted for K-swap ready. Fuel and brake lines are cut at the front setup ready to do a brake line tuck.
*Subframe/LCA/Forks are freshly powdercoated ready to be put back in.
*Please NOTE: If you are from Ontario, this car cannot be registered on the road. Great for track/race car only (Please inquire). If you are from any other Provinces in Canada, please do your research to see if you are able to register the car on the road. Different provinces have different rules.
If you are from the US, you can bring this car back no problem from Canada. Again please do your research to see if you are able to register the car on the road in the US (Other than the state of FL) Again, I am sure every state have different rules and regulations when it comes to (Junk/Irrepairable Titles) and are able to get it on the road as Salvage.
I need opinions on a fair price to ask for a fully restored, 3 owner, clean title, k20a integra type r. If youve never paid for any parts on my list then you probably shouldnt give an opinion. No bullshit on this car.
First off many of you may not be interested in an altered car. This car has been altered and the color is closer to navy/purple than the original flamenco black.
So onto the mods. Build can be seen on youtubehttps://m.youtube.com/watch?v=eSbmaY-lhT0 or under turbotex06 k20a integra
Engine: 08 k20a from an accord euro r. The motor is stock to my knowledge but miraculously made 256whp. I have the video and dyno sheet available.*
Its got a hondata intake gasket. A custom short ram intake, an asp 4-1 header for the k20a connected to a v banded hytech twin loop exhaust. Its still got ac and power steering. Its an older version 2 kpro.
Transmission: is the accord euro r as well. Its got lsd, carbon synchros, and all new sleeves and gear selectors. I used a 5 speed ep3 first and second gear with the euro r/type r 3-4-5 gears and tsx 6th with a 5.06 final drive. The clutch is an exedy stage one street disc and pressure plate. Nice setup in my opinion.
Suspension: full hardrace master kit. Every bushing has been replaced. Its also got hardrace front upper control arms and rear camber kits. The rear sway is an asr 24mm. Coilovers are tein type flex with the edfc. Brakes are ebc pads and rotors with Goodridge stainless brake lines. Its also got spoon rigid colars in the subframe and a full race traction bar. It can come with advan rg1s or the jdm 16s.
Body: Real 2000 type r with a clean title and 87,000 original miles. I put a jdm front, oem optional side skirts and rear valances and jdm rain guards.... and changed the color to a custom very dark blue/purple that looks black unless you look hard.
Interior: I have 2 interior setups. The first is the jdm theme with the jdm momo steering wheel wrapped in red suede along with the jdm red recaros and VERY RARE Canadian type r red rear seats. I also have another FULL set of the Canadian red seats front and rear (extra $1000) with the usdm steering wheel and custom door panels with the dry carbon inserts to match the dash vents, cluster, etc. The cluster is a ukdm 160mph type r with the mileage set to match my shell. Mugen rear view mirror, and Its got navigation and everything works as it should.
I selling the car as it sits with one set of wheels and the jdm/cdm set of interior. For any more info text me at 8455978926. The only trades im interested in are an nsx or r32 gtr plus cash on my end if its worth it
I've been following the for sale trend of ITR's for a couple of years now, so take my opinion for what it's worth. Typically, people don't post what the cars actually sell for so it's hard to gauge actual selling prices. You can sift through some closed eBay transactions for comps, but I typically find that eBay is either very underpriced or inflated, typically to cover eBay costs. Forums are a little better representation for the R market in my opinion, because most R owners visit this forum or ITRCA and this is where the market is.
People trying to buy ITR's are now buying them either for dedicated track use or collector/occasional drivers. Theres few in-between that are fetching decent $$. Unfortunately, I don't view this car as more than a DC2 with Recaro interior, off-color paint, and a K engine swap. Parts thrown together on a repainted R chassis, if you will. Your market for this package is either someone wanting to strip the car, sell the interior, suspension, and wheels and turn it into a track car or a kid who wants an Integra with a K motor and Recaro interior. -and can tell his friends that the car was born as an ITR but now has a custom paint job. The F&F fad died about 10 years ago.
The Canadian car above you is priced at $13k asking, restored.
I've watched a few other ads where the prices were dropped to a desperate $9k, bottom dollar on clean titled caR's, and sold. ITR Expo Forums: 2000 PY ITR
I think it would be difficult to fetch more than about $9k as it sits, being realistic. If it were an ITR color respray with badging and super clean, I don't think it would be difficult to pull $13k-ish, realistic.
So all of that said, I am sure you won't like my thought as I found yours on ITRCA for $16.5. For what it's worth, you did ask for opinions. ITR Expo Forums: k20a integra type r 00-1534
1999 Honda Civic Type R EK9
Car is registered
114 Kilometers
Tien Coil Overs ( With stocks Also)
Tien Dampers
Tein Strut Bar
Spoon Mirrors
Security
Pioneer Touch screen
Cars Completly Stock Overall (Unmolested!)
Located in North NJ
No Rust!!
Under the car is very clean!
Asking 16,000 Firm
Anybody willing to trade a black usdm TypeR for my 97 Type R please lmk car has a clean title JDM r swap OEM swap got hydrolocked painted last year car did had rust but now looks better 125k on the shell 97-0005 faster response text me 8572210830 car runs and drives has slight oil leak currently at a friends garage ready to drive anywhere I prefer black ask for pictures I have some
Anybody willing to trade a black usdm TypeR for my 97 Type R please lmk car has a clean title JDM r swap OEM swap got hydrolocked painted last year car did had rust but now looks better 125k on the shell 97-0005 faster response text me 8572210830 car runs and drives has slight oil leak currently at a friends garage ready to drive anywhere I prefer black ask for pictures I have some as for the black prefer clean title want a fair trade as good as my car
Originally Posted by Jdm917
This guy been low balling me for the longest now he's mad and comes and says this because I wouldn't wanna sell him the car lol
I was very respectful and nice to you... and never even made you a single offer.
I asked if you were flexible on price and you responded with "How much you got" and thats it... GTFO with your childish gangster talk.
When asked for additional pics, you sent some pictures of the jdm stickers in the door jams along with the same pictures you had already posted and a video of one half the exterior of the car played over some odd rap song or something.
Your communication with me was childish, immature and rude... this is something the ITR community is not about. We help each other, its what has made this community great for the last decade that I have been a part of it.
