Ground Controls - which rates??
I have a 2000 Ex that has undergone a complete Si conversion. Before the engine swap, the standard spring rates on my GC coilovers was working fine. However, after the swap, I notice a lot more nosedive when braking, especially if braking hard, and seems that the rear could use some stiffening up as well. I have been considering ordering stiffer springs from GC for a while, but am not sure which rates to go with.
The rest of the suspension is KONI Yellows, comptech sway/tie combo, 15" rota slipstreams with 205/50/15 falken azenis. The car is mainly used for commuting, autocross, and am planning on attending open track events in the near future.
Any help/experiences would be much appreciated. TIA
bigger engine=heavier..raise the front end up a little..if you feel its to loose then buy something stiffer that meets your auto Xing needs
[Modified by STEALTHMODECOUPE, 10:45 PM 11/6/2002]
get the integra rates. most likely you would need to upgrade the fronts to a higher spring rate, then put the ones that used to be in the front, on the back. then throw away the ones that were on the back.
confusing? yes
confusing? yes
I thought about doing that, but the spring that is currently in the front is an inch longer than the one that is currently in the back. Will that be a problem?
i am not familiar with GC that much(i only had one set and it was for a 92 Sentra SE-R)
but i do know that thats how the skunk2 kits are. the spring rates are:
integra:
front=10k
rear=8k
civic:
front=8k
rear=6k
integra:
front=10k
rear=8k
civic:
front=8k
rear=6k
Neo
Jun 11, 2002 09:06 AM
