valve guide with toda spec c cams
hello,
my name is andre.
i need your help.
i build a b18c with the following parts:
toda pistons
max. relieved crankshaft
compression is 13:1
the b16a1 head has a great head work
buddy club valve springs/retainers and valves
toda spec c camshafts /huge exhaust and twm itb
it gets a programmable logic conroller with a other ignition.
so i want to know the essential distance i need between retainer and valve guide. toda illustrate in the data sheet the size 12,55 mm for the size between top edge of the valve guide until the bottom. currently i have 13 mm. the maximum lift oft the camshaft is in/ ex 12,5 mm
so does anybody know the distance i need? is the specification of toda obligatory for driving the cams? i heard guideline value the size 1mm between retainer and valve guide. does it works with 0,5 mm?
thanks for your help.
best regards
andre
my name is andre.
i need your help.
toda pistons
compression is 13:1
best regards
andre
with the valve stem seal i´ve a distance/ tolerance of 0.5 mm. the maximum lift of the valve is 13 mm with the current valve train and the oem valve guides.
tomorrow i´ll spend more time for it.
yesterday we used a test gauge and the result is 0.45 mm distance between retainer and valve stem seal. so i would take the guidelines from toda and try to press the valve guides a little more...
can be closed-
can be closed-
Mike95lude
Oct 21, 2002 08:11 PM
