guage cluster.
Old Nov 5, 2002 | 07:42 PM
91SIvic's Avatar
Default guage cluster.
i have a 91 civic si, and i recently broke my cluster, and im needing to replace it, can i get any year? 88-91 and any model? or do i have to get the 91 si?
Old Nov 5, 2002 | 08:13 PM
Aphrodavid's Avatar
Default Re: guage cluster. (91SIvic)
as far as plug and play compatibilty, youll need to stick with the 90-91 clusters, the 88-89 are wired different. if you want a tach, youll need an SI, LX, or EX cluster.
Old Nov 5, 2002 | 10:04 PM
crazyfiz's Avatar
the '88 - '89 is shaped diffent so u would have to change your dash only the '90 -'92 would fit it.
Old Nov 5, 2002 | 10:09 PM
Vinceg99's Avatar
Default Re: guage cluster. (Braveheezy)
You can also go with a DX I have one and it also has a tach in it.
I have a 91 DX cluster for sale with zero miles on it only problem is it has the automatic thing in between the fuel and temp gauge get face gauges though and it would cover it right up.
Old Nov 6, 2002 | 03:31 AM
SuperCivic's Avatar
Default Re: guage cluster. (crazyfiz)
90-9 1
Old Nov 6, 2002 | 06:11 AM
zcivicz's Avatar
you wouldn't need to change the dash for the 88-89 clusters w/tach to fit in a 90-9i civ. you just gotta get the brackets and do some wirings mods but get the 90-91 A LOT easier!
hey guys i don't like how the cluster cover is so small on my 89 civ. can't i just throw on the 90-91 cluster covers ???
Old Nov 6, 2002 | 06:43 AM
xci_ed6's Avatar
Default Re: guage cluster. (zcivicz)
you can swap any thing you want. The parts that make the gauges work are the same from any year. the faces are different, but you can swap them. simply pry off the needle with two spoons and remove the 2 screws, then put on the working "driver". All of the contact points line up and everything.
-Dustin
wongburger
Dec 13, 2009 08:39 PM
kizner
Dec 30, 2005 05:44 PM
JackAcc
Aug 15, 2003 05:16 PM
88hondahatch
10
Oct 25, 2002 06:39 AM
Louie B.
Jan 30, 2002 02:23 PM
