pump took a dump now for a new pump
Old Oct 25, 2015 | 09:49 AM
NovaRex's Avatar
Default pump took a dump now for a new pump
alright fellas now that my pump is out im debating wether i should put in a high flow pump, my question is do i need to upgrade anything else before putting a fi flow pump? is there a chance it will flood the engine with everything stock? also the next upgrades will bee a intake manifold, and injectors.
Old Oct 26, 2015 | 02:44 AM
Freemananana's Avatar
Default Re: pump took a dump now for a new pump
First off, what car is this and what engine? Secondly, you don't need upgraded injectors based on what you are stating. Third, you don't need anything but a OE replacement pump based on what you are stating. If you want an aftermarket pump, go with a Walbro 190 lph. I would stick with an OE replacement pump based on your goals and stock injectors. Nothing you've stated will push the stock fueling system and the intake manifold could even lose power without a proper tune.
Old Oct 26, 2015 | 09:44 AM
acmoc's Avatar
the aftermarket ones dont last very long
Old Oct 26, 2015 | 12:48 PM
BLU CIVIC's Avatar
Track Advocate
I agree with both ^
Unless you have some plans that will require an upgraded fuel pump, then there is no need to get one.
ahobbs
Feb 23, 2011 11:08 AM
Btothe3rdDegree
Jul 29, 2004 09:08 AM
recall
May 5, 2002 04:11 PM
GSR_Dude
Oct 25, 2001 11:28 PM
smoothludey2
Oct 18, 2001 06:06 AM
