OBD2b No Tach
Hi guys and girls I did a manual swap on my 2000 civic ex 2dr I got a p28 ecu and a obd2b jump harness my problem is that my rpm don't work but when I plug the automatic ecu back rpm work fine I try the p28 with the jump harness on others that are manual from factory and it work fine I can't find nothing on the search engine I need help oh and when I start the car the rpm jump and stay down
Tach signal comes from the ecu on obd2 but from the distributor on everything earlier. If it's not built into your harness adapter, you'll need to figure out a way to get tacho pulse to A19 on the obd2 side.
Honestly I don't remember 100%, it's been about four years since I did mine. Search around. You're far from being the first person to have this issue, but I'm confident that's the problem.
OhioSI
Jan 17, 2017 09:12 AM
firejackal
13
Oct 28, 2015 03:02 PM
