air to water setup issue.
So I run a air to water setup on my k20 and keep having a issue with cooling. The pump keeps air locking after a pull, I can drive around with no issues (Only happens after a pull). The air temps get pretty high even with ice in the tank. Tank has a -8 vent, all the water line's are -12 with a pt1000 core and pretty big pump (Can't remember the name off hand). Could it be a core issue? Maybe the pressure under a load causing this? I'm stumped at this point, a buddy runs the same stuff I do on a similar setup and never had an issue. Thanks!
I don't have any right now but I will snap a few in the morning. The pump is mounted underneath the water tank on the bottom of the car. I keep the tank pretty full with water so it shouldn't even move enough to let air into the pump unless it's sacking it in somewhere else. Damn thing is a headache smh lol.
96 GSR-T
Apr 27, 2010 05:57 AM
