B16 swap
Aye, if anyone can help me out with a video or anything on how to completely do a correct b16a swap into a 92 eg 4 door? I bought it swapped and and covered to 5 spd. For 500 bucks. It just has minor issuse. I just need a video and I'm sure I could figure it out from there. Also if anyone could lmk what ecu I should run and how to run the reverse sensor to the lights again. It's on a toggle atm.
You're new, so you get one freebie. You just used it.
Read the rules. Read the FAQ sticky. Literally all of the information you need is right there for you - we aren't here to spoon feed you any further than we already have.
What are you talking about. All I need is you to point the direction that's all... can't expect me to understand evrything through writing. If I could see an example of pictures or videos them it'd be a piece of cake! But thanks I guss for nothing...
...Are you serious right now? Do you not understand what a stickied thread is? Hint: They're the threads with gray backgrounds, quite literally stuck to the top of the forum.
https://honda-tech.com/honda-civic-d...sting-3002401/
https://honda-tech.com/honda-civic-d...tions-1998336/
https://honda-tech.com/honda-civic-d...-vtec-2987229/
Consider yourself pointed. You came to a forum, which is inherently a text-based place for the free exchange of information. If you are quite literally the only person in the world who can't understand things through text, then you seriously should have reconsidered where you came for advice.
Can you please explain what your problem is and maybe we can help?
Someone really managed to mess up the reverse lights? it's a cone like sensor that sits on the bottom of the trans with a 2 socket plug and the female side is on the harness portion. Why cant you simply look in the engine bay in that vicinity for a lose plug(s) and connect them, it's the only square plug down there.
Is the B16 OBDI or OBDII?
Prostreetonline-VTEC Swap Guide
Cspeedracing-b18cswap
Google can find a few more references for you, but without knowing what trim level eg you're swaping into it's difficult to know exactly what needs to be done with respect to wiring. There are differences for an EX and DX/LX.
eH.
LoKiSiMo96
Jan 26, 2013 09:12 PM
stripes777
Mar 4, 2004 01:26 AM
