ecu to engine e harness questions.
Old Oct 22, 2015 | 09:07 PM
tasco's Avatar
Default ecu to engine e harness questions.
I have a 1994 civic cx that I just swapped a 1994 b18c1 into. Im using the gsr engine harness and ecu. But im getting check engine codes 23 and 41 for the knock sensor and for the o2 sensor heater. Is this because the civics harness is not wired for this? And is the harness that goes from the engine harness connectors to the ecu the same harness that goes through out the whole dash? I have access to the whole gsr wiring harness but will it fit the civic? The previous owner butchered the civic harness so I would really like to change that out, but if I have to take the whole dash out I will have to rethink swapping it out.
Thanks for any help.
Old Oct 22, 2015 | 09:22 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: ecu to engine e harness questions.
See this thread.
https://honda-tech.com/honda-civic-d...-vtec-2987229/
Specifically, these sections.
CX - D15B8
For VTEC wiring see above pic. For knock sensor and IAB wiring (see figure 1) (if using the chipped P28 you won’t need to wire IAB or knock sensor). If your CX model is NOT 4 wire you will need to wire up the 3 additional O2 connections below to the ECU (figure 1). All other wiring is plug and play.
The thread is stickied for a reason.
Old Oct 22, 2015 | 09:44 PM
tasco's Avatar
Im wondering if the civic and integra ecu harness are interchangeable? Would I have to remove the dash to swap it out?
Old Oct 22, 2015 | 09:57 PM
NotARaCist's Avatar
...You don't need to. Did you even bother reading the URL I gave you?
Old Oct 23, 2015 | 06:04 AM
tony_2018's Avatar
Fish Twig
The gsr engine STOPS at each shock tower, which means there are probably some wires not ran all the way to the ecu.
Old Oct 23, 2015 | 10:00 AM
tasco's Avatar
the previous owner spliced into a bunch of the wires to run a vafc and its getting bad connections somewhere. . That is why I am curious if the integra and civic harnesses are interchangeable.
Old Oct 23, 2015 | 03:30 PM
tony_2018's Avatar
Fish Twig
All you need to do is locate the wires ran to the o2 and the knock sensor and confirm they are not loose, check continuity back to the ecu to ensure you have a connection. Thats it. If you want to replace the the engine harness than swap an obd1 gsr in there.
fleabag
Jun 4, 2011 08:55 AM
jhendry
Dec 12, 2010 08:46 AM
Mr. Roboto
Dec 18, 2007 05:45 AM
carlosd68
Nov 8, 2006 11:09 AM
4g4me
Apr 22, 2002 09:23 AM
